magenta tint on faces shooting sony F55 and Venice
#1 ricardo de gracia
ricardo de gracia
  • 23 posts
Posted 25 November 2018 - 03:46 AM
I am getting some magenta tint on faces, shooting interior with Sony F55 and Venice. It appears when checking image with 709.
I am using 3.200K led panels as a main source, bounced on big blankets
how to avoid that slight magenta tint (what is that? blood reminiscence?)
what gel would you recomend on main source to make faces look more "Young and Golden look"?
#2 Mark Kenfield
Mark Kenfield
  • 1240 posts
Posted 25 November 2018 - 05:01 AM
Can you dial in bit of minus green on the cameras?
#3 Robin R Probyn
Robin R Probyn
  • 2614 posts
  • Tokyo
Posted 25 November 2018 - 06:34 AM
Are you using the REC709A  MLUT to monitor the f55.. (the A is for Arri Look).. Ive read people say this can give a magenta tint to skin tones.. although personally I haven't found  it to be the case.. but it is a known "thing".. The Venice has a new 709 color science called Lucent ..most likely also more of an Arri look.. color saturation roll off.. rather than the older Sony.. "color chart " only approach .. f55 you are stuck with preset only WB in Cine EI.. the Venice you can change in camera..
It could also be your  LED lights of course..   although I would doubt it if they are manufactured by the usual suspects .. and set properly ..
