Questions about anamorphic 35mm that have me wondering.
39 replies to this topic
#21 Tyler Purcell
Tyler Purcell
  • 4023 posts
Posted 06 November 2016 - 10:40 PM
2Bs are post-war cameras,
Yes, I apologize for my grievous error. I was referencing the II itself, rather then 1950's model that came later. I got the years mixed up, I was going off memory and was off by 10 years.
I also thought the Academy camera gates (full height) were taller then the Academy projection gates. This way cameras COULD use 2X anamorphic lenses without a problem. I thought that was just common knowledge as all the gates I've seen are full height, but protect the side for the soundtrack area.
#22 David Mullen ASC
  • 20038 posts
Posted 06 November 2016 - 11:38 PM
I've seen many older cameras with actual Academy gates.  And I've seen plenty with Full Aperture gates but the lens is centered for Academy and the groundglass is Academy.
I've never run into a physical gate that was cut to Full Aperture height but Academy width other than ones that can take an anamorphic aperture hard matte, but if you've run into some, I believe you... it's just odd that they would be labeled as "Academy" gates since that's not what defines what "Academy" is. (Maybe in this case "Academy" just means a sound format.)
Either way, the lesson here is that you should never assume that the labelling for the camera gate and lens mount centering is accurate without checking it yourself because there are definitely older cameras out there with Academy Aperture gates that hard matte the exposed image to 1.37 : 1, not 1.20 : 1.  If you slip in an Academy hard matte into the gate of a Panaflex, for example, you'd get a 1.37 image.  I used to use one in the movies I shot on a Panaflex just to make it clear to the telecine operator doing dailies that the movie was not Super-35... this was because I was too chicken to do what Allen Daviau did, which was use a 1.66 hard matte in his Panaflex movies.
#23 David Mullen ASC
  • 20038 posts
Posted 06 November 2016 - 11:54 PM
This old discussion covers some of these topics:
http://www.cinematog...showtopic=44954
Since someone describes a viewfinder that could see Full Aperture height but not width, you are probably correct that their gates covered Full Aperture height but Academy Aperture width -- so could be used for anamorphic. But it's not clear that the camera gate itself is actually cut in those dimensions or just the reflex viewfinding system is limited that area.
As I said, one of my operators owned an Arri-2C that I used for a few shots in "The Astronaut Farmer", which was a Panavision anamorphic show, but since I never saw a workprint of that footage, I can't tell you if the soundtrack area was masked off by the camera gate.
#24 Tyler Purcell
Tyler Purcell
  • 4023 posts
I just noticed the ground glass was more square then normal. So I pulled the gate out and marked a piece of film and was shocked to see it had full height, but still protected the soundtrack area. I didn't notice any markings that mentioned academy however. I probably should have measured it.
Does that make any sense?
#25 David Mullen ASC
  • 20038 posts
Posted 06 November 2016 - 11:58 PM
Yes, it makes sense... I've only used a rented Arri-2C a couple of times in my career, all for standard 1.85 or anamorphic movies, not Super-35, and I never really got a good look at the shape of the gate in terms of whether it masked off the soundtrack area.
#26 Tyler Purcell
Tyler Purcell
  • 4023 posts
Posted 07 November 2016 - 12:05 AM
Got ya, good so I'm not crazy! I'll own one very soon, got one being donated to my school, looking forward to playing with it. :)
Thanks again for the info!
#27 Dom Jaeger
Dom Jaeger
  • 1689 posts
  • Melbourne, Australia
Posted 07 November 2016 - 04:03 AM
Not a grievous error, just one more fact you confidently assert that turns out to be false.
So when you say "all the gates I've seen are full height" do you mean just the one that you pulled out to inspect?
As I mentioned before, the scope gate for 2Cs is full height at 19mm but not full silent or S35 width, with an aspect ratio of 1.2:1. It's centred for Academy like the standard gate which is only 16mm high x 22mm (1.375:1).
I believe part of the reason the Arri 35 models don't have full aperture gates is because the claw is right next to the aperture and its cutout in the gate doesn't leave enough room for a support rail if the aperture was extended all the way into the soundtrack area.
Later Arri 35mm cameras had full aperture gates with interchangeable masks if required.
I'll try and post some photos when I get time.
#28 David Mullen ASC
  • 20038 posts
Posted 07 November 2016 - 10:38 AM
Actually I think Tyler in this case was confirming what you are saying, that the gates were Academy width but Full Aperture height -- what I was wondering is:
-- Would such a gate be labeled by ARRI or any seller as "Academy"?
-- Were there actual "Academy" gates sold for those ARRI cameras -- sounds like you're saying that there were, so I assume that the taller anamorphic gate should not be called an Academy gate.
If there is any confusion on the market out there, it's up to the buyer to make sure his camera has the type of gate he needs.
#29 Dom Jaeger
Dom Jaeger
  • 1689 posts
Posted 07 November 2016 - 07:53 PM
My query was whether Tyler had made a general assumption about all 2C gates based on inspecting just one.
I don't know what Arri called the larger gate, I imagine it was something like Scope or Cinemascope. The Academy gate is the standard 1.375:1 smaller one. There is no written identifier on them, so I'm sure some people might get confused and label them both Academy. The scope gate is actually wider than Academy, but not enough to be full aperture.
From what I've been told by someone who has used and owned a number of 2Cs since the 70s the scope gate was a special order item, but many owners had one and used them for both anamorphic and spherical shooting.
On the left a standard Academy gate, on the right a scope gate. Note the very thin support rail on the right edge of the scope gate (which is the soundtrack area) due to the cutout for the claw.
#30 Tyler Purcell
Tyler Purcell
  • 4023 posts
Posted 07 November 2016 - 11:26 PM
Yea exactly, it's kinda confusing. Thanks for posting that thou, good to know.
#31 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 08 November 2016 - 02:06 AM
Are there some quirks about shooting 2x anamorphic that might be encountered if you've never shot anamorphic before - particularly in relation to film? There's lens flare and bokeh, and obviously it's the 2.40:1 format. I mean potential issues of camera movement, pans and the like, should these in general be slower, should there be less camera movement, maybe no handheld, compared to spherical shooting, to get the most out of the medium? Maybe there's no real difference and you quickly get used to it, beyond the obvious compositional differences. Camera and lens combination would be a lot bigger, making some shooting a bit more difficult.
Rental lenses has got me thinking. Buy some short ends, get processing and DI in Sydney. I already have a great old wooden tripod (for a theodolite!) made by Kern so would just need a head for it.
#32 Mark Dunn
Mark Dunn
  • 2640 posts
Posted 08 November 2016 - 07:52 AM
My Samuelson's manual says that an object shouldn't cross the FoV in less that seven seconds for 'scope, as against five seconds for flat with a 170-180deg shutter, but I suspect that that rule is honoured more in the breach than the observance nowadays.
Edited by Mark Dunn, 08 November 2016 - 07:52 AM.
#33 David Mullen ASC
  • 20038 posts
Posted 08 November 2016 - 11:07 AM
I don't think anyone really changes their panning speed for anamorphic, or editing speed, though a wider frame may or may not allow you to cut less often.
There are quirks to watch out for like the minimum focus, some anamorphic lenses don't focus that closely.  And breathing is so bad sometimes that you have to really think about when to rack focus to something, you can't ping-pong the focus back and forth during a dialogue scene, for example.  And if your anamorphic lens creates horizontal flares, you have to think about where the flare will cross the frame because you don't want it covering an actor's eyes.  And with the generally shallower depth of field, it's harder to hold two things in focus at a time.  The wider-angle anamorphic lenses have a lot of barrel distortion in them so vertical lines will get bent at the sides of the frame.  Most anamorphic zooms are rear-adapted conversions and are about a stop slower than their spherical counterparts, so many don't open any wider than T/4.5-ish.
#34 Will Montgomery
Will Montgomery
  • 2059 posts
  • Dallas, TX
Posted 11 November 2016 - 10:14 AM
2B's and 2C's have to be the most modified cameras in the history of cinema. I've never actually seen a "stock" un-modified Arri 2C. Different gates, mounts and motors...never the same thing twice. I love my Steve's Cine modified 2C with PL mount and wonderful crystal motor.
#35 Tyler Purcell
Tyler Purcell
  • 4023 posts
Posted 11 November 2016 - 12:34 PM
I recently saw an "almost" all original IIC at a camera sale. It had the original Arri hand grip motor tripod adaptor and everything. Very sick kit, I would have snatched it if the seller didn't think it had some value. He was using it for decoration at his house so it was just a body and magazine, but he wanted $7500 bux for it because someone told him it shot MOS shots from The Godfather. It was the closest thing to "original" I've ever seen. Pretty neat piece.
#36 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 18 November 2016 - 05:46 PM
Apparently there were a few 2C's that were converted, maybe around 30 years ago or more, to PL hardfront, and the gate was custom machined to full aperture S35 (not the Scope gate). One sold listing I looked at on ebay went into a bit of detail and said these cameras were set up to be used either for Super 35 or for anamorphic. But that can't be right as the lens must be centred for one or the other. Were these early S35 conversions, maybe for TV series filming non-dialogue shots? Is it possible to tell just by looking through the lens mount if the lens is centred for full aperture or for sound - how wide, approximately, is the optical sound track on an anamorphic 35mm print - maybe 2 or 3mm? Peering through the film door, the right hand side of the gate on an Arri 2C would have to be very close to the film claw slot, as Dom said, on a S35 conversion.
Edited by Jon O'Brien, 18 November 2016 - 06:01 PM.
#37 David Mullen ASC
  • 20038 posts
Posted 18 November 2016 - 05:55 PM
I believe "Silverado", an early Super-35 production, used some of those ARRI-2C's with full aperture gates for a few shots... I don't think the mounts were shifted over from Academy, but as long as the lens image fills enough of the frame (easier when you're going to be cropping to 2.40) it might not noticeable if the lens isn't optically centered side to side. After all it's not centered top to bottom when shooting common-top.
#38 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 18 November 2016 - 07:17 PM
Ah, so my thinking has probably been too 'perfectionist'. The lens doesn't really need to be centred. Only in zoom shots there would be a problem. Still, I suspect some of these conversions may have been centred for S35. I'm actually getting more interested in Super 35, and less interested in anamorphic, at least as a way to get started with 35mm. Easier to find lenses, and more image area than 2-perf.
Edited by Jon O'Brien, 18 November 2016 - 07:22 PM.
#39 Jon O'Brien
Jon O'Brien
  • 377 posts
  • Brisbane
Posted 18 November 2016 - 07:42 PM
Here is probably a really dumb question but I'm sorry, I must ask it. In the original purely photochemical Scope filming process, circa 70's, does the camera negative have to leave unexposed the little area of the film frame where the soundtrack later goes, or does it not matter? I'm guessing it did have to be left unexposed, due to the contact printing process. If the area where the soundtrack went contained image in the original negative then this would also be exposed on the contact print, spoiling the area where the optical soundtrack was to be added.
Edited by Jon O'Brien, 18 November 2016 - 07:45 PM.
#40 David Mullen ASC
  • 20038 posts
Posted 18 November 2016 - 08:01 PM
It didn't matter, when making the contact print, the printer can mask that area off.  Optical tracks could either be silver or dye -- if silver, it was an application to the edge of the print so that the optical track could be exposed and developed onto it.
We had a discussion about printing here:
http://www.cinematog...showtopic=61134
