Moviecam SL "MOV" error
42 replies to this topic
#41 Satsuki Murashige
Satsuki Murashige
  • 3510 posts
Posted 28 July 2016 - 07:59 PM
Perfect, thank you Dom. I think Arri must have sent us Arricam oil rather than chronosynth 1/8 then because Jorge mentioned that his old bottle of oil was much more viscous and dark in color than what they sent him. Will check in with him. Thanks again!
#42 victor huey
victor huey
  • 98 posts
Posted 06 August 2017 - 08:23 PM
i have two moviecam compact mk 1 cameras, one has a cinema electornics module replacing the OEM one. The other is original, but is powered via four pin. The cinema electronics is three pin. I am not sure how much voltage each requires or the proper wiring?
#43 Dom Jaeger
Dom Jaeger
  • 1630 posts
  • Melbourne, Australia
Posted 06 August 2017 - 11:41 PM
Moviecams are 24V cameras, at least the SL and Compact MkII are, I would assume the Mk1 is the same.
We talked about power socket wiring in this thread:
http://www.cinematog...showtopic=65058
The original Moviecam wiring was pin 1 ground and pins 2 and 4 +24V, but some rental houses altered the wiring to avoid mix ups with the 12V standard power plug which was a 4 pin XLR wired to pins 1 and 4. You may need to remove the side cover to check the wiring.
The 24V (non-Panavision) standard was a 3 pin XLR wired pin 1 ground and pin 3 +24V, which is how I would assume the CE module is wired.
Opal
Opal
