Cinematography.com: The 1st needed convincing, the grip wasn't sure, everyone else was sold - Cinematography.com
  • (5 Pages)
  • « First
  • 3
  • 4
  • 5
  • You cannot start a new topic
  • You cannot reply to this topic
#81 User is offline   Stephen Williams
  • Group: Sustaining Members
  • Gender:Male
  • Occupation:Cinematographer / DP
Posted 14 November 2005 - 04:36 AM
View Postkeith mottram, on Nov 14 2005, 01:28 PM, said:
2/4 split as far as i can remember, cooke s4's and arri master primes- but don't quote me.
Keith
Keith,
Did you see a difference between S4's and Master Primes? I have never seen a comparison!
Cheers,
Stephen
0
#82 User is online   Keith Mottram
  • Gender:Male
  • Occupation:Other
Posted 14 November 2005 - 04:52 AM
View PostStephen Williams, on Nov 14 2005, 04:36 AM, said:
Keith,
Cheers,
Stephen
To be honest no and i have no log of which were used for which shot, I think they were just preferences by the DP for one over the other on certain lengths. With regards to the softness of the images- i have worked with a large amount of 35mm scanned to HD and I wouldn't say I notice a considerable difference (apart from the lack of grain!!). When the footage is played back at HD it does not feel soft. These shots are ungraded if anyone is wondering.
Keith
0
#83 User is online   Keith Mottram
  • Gender:Male
  • Occupation:Other
Posted 14 November 2005 - 09:30 AM
there also might be some softening in the export from qt to tiff. i did an export from shake to cineon file and they seem to be sharper.
keith
0
#84 User is offline   Justin Barham
  • Group: Basic Members
Posted 22 November 2005 - 06:16 PM
View PostDavid Mullen, on Oct 31 2005, 06:13 PM, said:
Sometimes I think the technical aspects of moviemaking are overrated -- I almost agree with Kubrick who felt that the technical side of filmmaking could be learned in a week (but perfected over a lifetime, of course.)
Sorry to go OT, but I believe Kubrick said that film theory could be learned in a week. Correct me if I'm wrong.
0
#85 User is offline   Paddy Eason
  • New
  • Occupation:Other
Posted 21 April 2006 - 08:10 AM
View PostJim Murdoch, on Nov 2 2005, 03:18 AM, said:
Huh? Well, 1,920 x 1080 x 3 = 6,220,800 nicht wahr?
Anyway I've seen an e-mail from John Galt about this. He said the 12,440,800 pixels are arranged in square "macropixels" of two red, two green and two blue each. I would have thought they would have been arranged like this:
RGB|RGB|RGB
BGR|BGR|BGR
RGB|RGB|RGB
BGR|BGR|BGR
to reduce alaising effects, which is what they do with single-chip standard definition cameras that use this technique, but he said no, they're arranged like this:
RGB|RGB|RGB
RGB|RGB|RGB
RGB|RGB|RGB
RGB|RGB|RGB
and he didn't seem to understand why you'd want to do it any other way. He didn't seem to have any answer to the question: "why do they simply average adjacent pairs of pixels, instead of having just one taller pixel (which would give a better signal-to-noise ratio)?" either. He stopped replying after that!
I'm certainly no expert, but I think you are misunderstanding the way Bayer arrays work:
http://www.arri.com/news/newsletter/articl...9211103/d20.htm
0
#86 User is offline   Jim Murdoch
  • Interests:real name keith walters
  • Occupation:Other
Posted 27 April 2006 - 03:36 AM
The Genesis doesn't use a Bayer Array, it uses exactly the layout I showed you.
I know perfectly well how a Bayer Array works, and the shortcomings it has.
0
#87 User is offline   Ted Johanson
  • Interests:Still photography, cinematography, computer programming
  • Occupation:Student
Posted 28 April 2006 - 10:54 AM
Quote
Hi Jim,
As I see from one of your earlier posts in this thread, you remembered my post from a year ago in which I gave my explanation for the Genesis using that particular sensor design.
For everyone who didn't see that post, here's my explanation... Every first row of pixels overexposes to capture shadow detail while every second row of pixels underexposes to capture highlight detail (see attachment).
Attached File  grid.gif (6.26K)
So, if you have 12,440,800 "pixels" (really photodiodes) to begin with, and you need to average every two rows of photodiodes into one row, you would then be left with 6,220,400 photodiodes. Then, because you need a red, green, and blue photodiode to produce a single pixel, you need to divide 6,220,400 by three, at which time you arrive at producing an approximate 2k, full-color image. It's as simple as that.
This seems to be the best explanation for using 12 million photodiodes to produce a 2 million pixel image. It would be the most advantageous use of having multiple photodiodes for each single primary color of every pixel. It accounts for the increased contrast handling capabilities of the Genesis.
And now that I think more about it, Jim is right in saying it would be too complex to build a chip in which the actual sensitivity of each row of pixels is different than that of the adjacent row. So, instead, they most likely place strips of ND filters over every other row of pixels so those rows can capture highlights better. However, after averaging the two rows together, the image would appear underexposed. The simple solution to that problem would be to recalibrate the sensitivity of the entire sensor to counteract the darkening caused by the ND filters.
I think those are the (former) "secrets" John Galt couldn't reveal.
-Ted Johanson
This post has been edited by Ted Johanson: 28 April 2006 - 11:00 AM
0
#88 User is offline   Daniel Stigler
  • Gender:Male
  • Occupation:1st Assistant Camera
Posted 30 April 2006 - 08:16 PM
View PostPhil Rhodes, on Oct 29 2005, 05:28 PM, said:
But isn't that the point? What's the purpose in using improved technology if it doesn't save you anything? The whole paradigm with this thing seems to be to make it as awkward, old-fashioned and backward as a film camera, for no better reason than ensuring the crew are employed.
I think you're slightly wrong here. To give an example: imagine doing a car commercial including dusty dirt roads and beaches in say South Africa where a lot of crane and remote head shots are done. When i put a 435 on a remote head i find plugs for the RCU connection and the power connection on the head. Set up time: 1 minute. When i want to do this with your usual HD camera, that was designed for broadcast use, i might be happy to even have a remote control unit that's of any use to me as an AC. There's a good chance i will have to install some extra cabling along the crane arm. Set up time: who knows. You see there are situations where it makes perfekt sense to build a machine "as awkward, old-fashioned and backward as a film camera".
Where each HD camera loses is the combination of heat and dust. With a 435 i just pull a plastic bag over it, cut a chole in front and tape the seems of the hole to the edges of the mattebox. Absolutely safe. When trying this with an HD thingie there are two possibilities: the plastic bag melts, dust comes in and fu**s up the usually - compared to old-fashioned filmcameras - crappy mechanical parts of the cam. Or the camera just overheats and the electronics die.
0
#89 User is offline   Paddy Eason
  • New
  • Occupation:Other
Posted 02 May 2006 - 03:37 AM
Ah - forgive me, I thought we were discussing the D20 here. Obviously the discussion switched to a different camera 5 pages ago, and I missed it.
For anyone who's interested, here are some small patches (actual pixels, no resizing) cut out of some D20 HD images from tests we did a few weeks ago.
Arri D20, shooting 4:4:4 uncompressed into the s.two. Camera shooting in "User 6" mode, which, if memory serves, is one of the higher gain (1 or 2 stops) video-ish colourspace settings, with highlight compression on.
Images taken into Shake, and saved out as highest quality jpegs. Yes, yes, yes, I know that conversion to jpeg potentially brings up a load of issues, but I think that you will still see some things of interest in these images. Most specifically the high level of noise in the red and blue relative to the green, and also the low resolution and "blockiness" of the red and blue relative to green. Also some obvious and colourful moire. Quite worrying. YMMV.
In the camera's defence, I should add that we shot a load of material of more "naturalistic" subjects, projected it all in a high-end grading suite with a high spec projector, and sat for a couple of hours commenting on how wonderful the material looked.
So it's probable that Arri have made the necessary compromises in the right places. Trouble is - I have a load of chromakey shots to worry about! ;)
0
#90 User is offline   Paddy Eason
  • New
  • Occupation:Other
Posted 11 May 2006 - 03:04 AM
Update - there's a chance the issues visible in these images were one-offs. Similar tests with another D20 didn't exhibit them. Further testing in progress, so for now, pls don't assume that all D20's will have these problems... of course if you are planning on using this new-ish camera, you would be doing your own tests.
0
Share this topic:
  • (5 Pages)
  • « First
  • 3
  • 4
  • 5
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Scan this QR Code with your phone and then add the page to your mobile favorites!
Cinematography.com
Mobile Access!
