Anamorphic on Eclair.
85 replies to this topic
#81 Samuel Berger
Samuel Berger
  • 1262 posts
  • Seattle
Posted 23 November 2017 - 01:02 AM
I've read this movie. I've worked on it. Hell...I have shoot it and never gotten anywhere because the director is an “artist” that is never happy with the final work...
But yes. It will happen.
That's why directors like that need angry producers. Add that character and production moves forward!
#82 Samuel Berger
Samuel Berger
  • 1262 posts
  • Seattle
Posted 23 November 2017 - 03:54 PM
I mean the adapter is a screw on. So unless I fit the rods tight under...it will always move with the lens...
C
Someone thought of that.
#83 Samuel Berger
Samuel Berger
  • 1262 posts
  • Seattle
Posted 23 November 2017 - 06:45 PM
Ok this is the procedure for using the LA7200 with a Canon film camera with 58mm filter thread. Might work out for you.
The LA7200 is a 72mm thread, use a step-up ring for 58mm (Canon) and an additional ring extension
because the LA7200 was made for DV and the clearance for the thread is limited and wont fit directly
in the step-up ring, for the extension I use an old 72mm polarizer without the glass.
Very important:
1- keep the anamorphic fully horizontal
2- Adjust focus and recheck anamorphic lens position
3- Avoid extreme short DoF
4- At the begining of every shoot put a perfect circular object in front of the camera (draw a circle in the slate)
this will be your guide in post for 16x9 correction
In other words, for the anamorphic support get an old 72mm skylight filter, break the glass , cut away the excess metal ring in the la7200 adapter, screw on both parts, the focus ring of the taking lens will fit and allow to focus perfectly, just keep the adapter horizontal.
Edited by Samuel Berger, 23 November 2017 - 06:55 PM.
#84 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 29 November 2017 - 04:22 PM
I finally made a transfer.
The Spirit Telecine was not having a good day, so I will go back another day to redo it. As well as reshoot it with more intersting lights to see the effect.
https://vimeo.com/245083339/9f46ebd4ff
C
Edited by Carl Nenzen Loven, 29 November 2017 - 04:22 PM.
#85 Samuel Berger
Samuel Berger
  • 1262 posts
  • Seattle
Posted 29 November 2017 - 06:10 PM
Well at least you know the adapter works. Even if the image is squashed down a bit more than you'd want it, that can be fixed in post. I'm not loving the transfer, though, so I'm happy you're doing it over. Did you figure out focus pulling?
#86 Carl Nenzen Loven
Carl Nenzen Loven
  • 183 posts
Posted 29 November 2017 - 06:37 PM
That is the proper desqueeze. 1.33
The spirit Telecine we have is old, so it means some artifacts indeed. But it won't be day/night difference.
C
