MINT- Angenieux Optimo 3D Ready Package with Two DP 16-42mm Matched Lenses w/case
optimo Angenieux 3D 16-42mm matched lenses
#1 Scott Snare
Scott Snare
  • 6 posts
Posted 07 December 2016 - 07:43 PM
Selliing MINT (only used twice) Angenieux Optimo 3D Ready Package with Two DP 16-42mm Matched Lenses w/case. These lenses are very hard to find. I paid $46K for the package - Asking $42,000
Local pickup in Los Angeles only.
Please email my assistant Deb at bigdreamsdeb@gmail.com with any questions or offers. If you PM message on here, there will likely be a delay in response.
Thanks!
Scott Snare
VIEW PICS: https://flic.kr/s/aHskJib6Xa
PRODUCT HIGHLIGHTS
Matched Lenses from Same Production Run
For Stereoscopic 3D Productions
For Cameras w/ Large Single Sensors
PL Mounts
Custom Padded Pelican Carry Case
The Angenieux Optimo 3D Ready Package with Two DP 16-42mm Lenses takes a lot of the headache out of stereoscopic 3D production by pairing two factory-matched, high-quality lenses. For shooting S3D with a beam-splitter or side-by-side stereo rig, matched lenses are absolutely crucial. These two Optimo DP 16-42mm lenses are from the same production run – a key consideration when you're trying to find twins of a device as mechanically sensitive as a lens. (Choosing matched zooms over two sets of primes is also a good way to ease setups for stereoscopic productions.)
The two super-fast lenses have matching focus scales – focus rings are perfectly calibrated – and zoom ranges, and tracking is easily adjustable. Their zoom range of 16-42mm is appropriate for most stereo-friendly shooting, which favors wide shots over close-ups.
The kit comes in a custom Pelican case with padding cut specifically for the included items: The two lenses, shim kits, two screwdrivers, two lens support brackets, and two focus sticks.
Note: The lenses do not fit on cameras with optical viewfinders.
PL mounts
Optical design optimized for large-format, single-sensor digital cinema cameras: 32mm diagonal image area covers entire active pixel area of an S35/5K sensor
Super-fast aperture of T2.8 (f/2.6), with no ramping
320º focus rotation with over 20 precise focus witness marks and no breathing
Calibrated focus marks in feet or meters
Angenieux 16-42mm
Focal Length 16mm-42mm
Max Aperture T2.8
Mount PL
Image Circle 31.4mm
Min. Focus 24"
Front Dia. 114mm
Weight 4.2 lb.
#2 Scott Snare
Scott Snare
  • 6 posts
Posted 09 December 2016 - 05:30 PM
Something happened with the flickr link - here is the new link https://flic.kr/s/aHskJqUgkx
#3 Scott Snare
Scott Snare
  • 6 posts
Posted 15 February 2017 - 03:08 PM
Price drop to $39500
