Best hand held option.
10 replies to this topic
#1 SSJR
SSJR
  • 53 posts
Posted 11 November 2005 - 06:44 PM
My choices are not so many:
Has anyone had hand held with these bad boys.
Arriflex 535B
Arriflex 35 BL4 Camera
:P
#2 Joseph White
Joseph White
  • 143 posts
Posted 11 November 2005 - 08:50 PM
Arriflex 535B
:P
i've had experience doing handheld with both (and much worse - like a moviecam superamerica or a bl-3 with a 1000' mag and a cooke zoom). of the two i'd choose the 535b as i'm sure it's lighter and its generally a better camera overall; newer, more sophisticated in general.
also don't necessarily run towards using 400' mags either. to me it's not as much about weight as its about weight distrubution, and often times i find using a 1000' mag for handheld felt more comfortable even though it was heavier. simply because all of the weight wasn't on my forearms.
and make sure your buddies are there to take the camera from you as soon as you hear "thats a cut!" and you'll be fine.
#3 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 12 November 2005 - 05:30 AM
The 535B is much lighter. Should be easier to handhold as well. I've done some handheld with a 535A (unfortunately) and as long as your weight distribution is decent it won't be that bad. Fold up some duvey and use it as a shoulder pad and grit your teeth. The absolute worst 35mm handheld camera has to be the Arri 3, and it's bad mainly because of the horrible balance on your shoulder. If the balance is good, even heavy cameras aren't so bad.
#4 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 12 November 2005 - 08:18 AM
I've handheld with 535 quite a bit, and it's a heavy camera but rather well balanced. Some guys prefer to shoot with the 1000ft mag to balance it up even more.
BTW, I know a DP who shot an entire feature handheld with the 535A. He is a couple of inches shorter today... :P
#5 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 12 November 2005 - 12:32 PM
Yeah I worked on a feature where the Dop did both handheld and steadicam wiith a 535A. It was not pretty.
But in general if I know I will only be shooting on dolly and sticks, then I'd much rater have a 535A, because of it's electronic shutter.
#6 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 12 November 2005 - 05:22 PM
Maybe you could borrow an Eyemo - it was the Hollywood handheld of choice in the old days.
#7 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 13 November 2005 - 07:06 AM
That would be a little tough when doing sync sound. It's a great crash cam though.
#8 hoytevanhoytema
hoytevanhoytema
Posted 13 November 2005 - 09:05 AM
are you sure about the 535A on a steadicam? I find it hard to believe....
I did some hand held on it during my last feature, and I liked it with the big magazine for balance... But, longer takes are troublesome... also, running with it is impossible... On a steadicam? Never in my life...
hoyte
#9 David Mullen ASC
  • 20072 posts
Posted 13 November 2005 - 11:50 AM
Well, Alfonso Beato told me he used Primo anamorphics on a steadicam for "Dark Water", which I also have trouble believing.
I've never used the 535A and I only did one feature on the 535B, but I liked that camera a lot -- a very bright viewfinder, which is important to me.
#10 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 14 November 2005 - 05:18 PM
You bet it was a 535A on a steadicam.
This was a really low budget film (around 750.000 ?), so we could not carry two camera bodies. And not hire a steadicam operator, hence why the Dop did it.
Anamorphic Primos on steadicam are okay, as long as it is a lighweight camera. If memory serves right, the lenses are about 5 kilos each, excpet the 50mm, which is 7 kilos. They probably used an XL or XL2, so the weight should have been manageable, the tricky thing is the balance, the camera gets very front heavy with these lenses. I know 2 operators who have done this as well.
#11 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 15 November 2005 - 05:37 AM
I'm sure it's doable, but probably not preferable. I've not done it myself, so I can't say for sure, but I know that my personal rig (master series) could handle the weight if needed. It would be tough on the operator, but definately within the limits of modern steadicam systems. If there was a lot of steadicam it would wear an operator down quickly though.
