7218 with no 85b
#1 tom quinn
tom quinn
  • 48 posts
Posted 23 November 2005 - 07:29 PM
hey all
i have a shoot this weekend and am using 7218 500T stock. I may be adding an outdoor component, but do not have a correction filter. Will I be able to warm this up when I correct during my transfer to digibeta?
thanks
tom
#2 Marcus Frakes
Marcus Frakes
  • 40 posts
Posted 25 November 2005 - 04:49 AM
Can you rent a filter or mattebox combo? I have converted such footage in post using color correction, but it's better if you shoot with a filter to start with.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 25 November 2005 - 05:59 AM
hey all
thanks
tom
For telecine you can get away with it, as a last resort. I always would try to correct with an LLD (no light loss) or at least an 85ef.
If you want to print there will be a problem as the blue layer is overexposed.
Stephen
#4 Sam Wells
Sam Wells
  • 1751 posts
Posted 25 November 2005 - 10:34 AM
Hi Tom !
More wiggle with than without. As you can get an 85 as easily as an LLD no reason not to.
If you who I think, you can rent filters @ Videosmith rentals. I've rented 85/ND combos etc there.
-Sam
#5 John Holland
John Holland
  • 2273 posts
  • London England
Posted 25 November 2005 - 12:36 PM
To honest cant remember i used a 85 filter , this is going back at least 15 years , if going to tape or print . Easy correction and you get that extra speed without filter . John holland . London.
#6 David Mullen ASC
Posted 25 November 2005 - 01:57 PM
The bigger problem of not using filters with 7218 outdoors is needing ND's if it's fairly bright outside. And if you get some ND's, you might as well make then 85/ND combos.
