F900 with XDCAM530 memroy stick
#1 ariel
ariel
Posted 27 November 2005 - 10:37 AM
I have a memory stick that I use with the 530 xdcam.
can I use it with f900? can I transfer information between the 2 cameras? For example if I have a file containing all my necessary info: progressive...16\9...vf settings...test out settings... can I read this file to the f900?
#2 Wes Shinn
Wes Shinn
  • 13 posts
  • Digital Image Technician
Posted 27 January 2006 - 08:22 PM
if its the same stick.....it should work.
#3 Brian Drysdale
  • 5198 posts
Posted 28 January 2006 - 07:23 AM
Although they use the same stick, you might find that the settings are different. For example the F900 and HDW 750 have different settings and they're both HD cameras (The menu layouts are also different). However, I suspect that the DSR 450 might have the same settings as the XDCAM 530.
