Transferring Reversal
7 replies to this topic
#1 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 28 November 2005 - 11:49 AM
I have a roll of reversal that I shot. It's been processed. I also have a lot of negative film for processing and transfer still left to be done. Can I include my reversal roll when sending my film to a lab? Will they transfer the reversal via telecine at no extra charge? I will be calling labs today but I wanted to know what to expect.
If anyone has done this can you post your experiences?
Posted 28 November 2005 - 11:54 AM
It's no problem transferring both negative and positive film on a telecine -- just warn the lab & colorist that one roll is reversal.
#3 Eugene Lehnert
Eugene Lehnert
  • 203 posts
  • New York, NY
Posted 28 November 2005 - 12:00 PM
Cool, thanks. Wasn't sure if there was going to be an extra charge or not. I wouldn't think so, but you never know.
I hand processed some film back in college and sent it to Bono films and they freaked out and called me about it when I asked them to transfer it. I had to explain that it was hand processed reversal and that I wanted it transfered as a postivie and not as a negative along with my other film.
#4 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 28 November 2005 - 12:03 PM
A different telecine/scanner setup is used for each, so they need to be in separate rolls. Would not be easy to handle a single roll with negative and positive images intercut.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 29 November 2005 - 03:07 AM
The colourist has to change the focus of the telecine as the image is on the other side of the film.
Stephen
#6 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
Posted 30 November 2005 - 08:59 AM
Stephen
If both are camera originals, the image orientation is the same (reads correctly through the base side). If the positive image is a direct contact print from the negative, then the orientation will be changed (image will read correctly through the emulsion side).
#7 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 30 November 2005 - 08:53 PM
This might sound obvious or even incredible . . . . but just a small tip: if you include your processed reversal with the unprocessed neg, make sure you label them all clearly, and keep the processed reel separate.
It's been known for a lab to make a silly mistake and assume that there wouldn't be one roll of processed film hidden amongst several rolls sent for processing. Disaster can ensue. Remember that the lab guys don't actually look at the unprocessed film!
#8 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 01 December 2005 - 03:27 AM
John,
Yes your right, I was thinking back 25 years in television when the negative was printed, so it was an issue to mix negative and reversal. I guess a Spirit with a Divinci could handle the colour correction change in real time!
Stephen
