Add-on Anamorphic elements.
#1 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 29 November 2005 - 09:06 PM
Hello fine folks,
Since rear elements are used for anamorphic zooms, could they be mounted behind flat primes to serve the same purpose?
Also, has anyone had any experince with the Lomo anamorphic elements (the ones that mount in front of a flat lens)?
Posted 30 November 2005 - 01:04 AM
Back focus is more critical with wide-angle lenses, plus they tend to already have a deep flange depth, so adding rear anamorphic attachments can be tricky and probably has to be done by a lens technician, plus you'd have to make sure it cleared the mirror shutter.
It's not unusual to use rear anamorphic attachments for telephoto lenses.
#3 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 30 November 2005 - 07:13 AM
The one attachment that I know of is a system developed by Thierry Tronchet. But it is for 16mm and it goes in front of the lens. It involves remarking the focus-scale on the lenses as well.
#4 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 30 November 2005 - 03:54 PM
Hello fine folks,
---The NAS (HAC in Cyrillic) attachments are designed to be used with specific lens which couple to the attachment abd have matching focus scales so the focusing is done on the anamorphic section.
The NAS-10 has a 35mm f/2.5 backing lens and the NAS-4 has a 50mm and 75mm. There is a 135mm which might be next to impossible to find.
These backing lenses are OST-18 mount for the Konvas 1M. It's similar to the Arri standard mount, but bigger, so the backing lenses rotate in the camera mount when focusing.
It ought to be possible to use the attachments with other lens. Obviously the focusing rings won't couple so both lenses would have to be focused seperately. Also the backing lenses slip into the anamorphic attachments, so finding other lenses that fit would be a hassle.
The same goes for the Foton-A zoom. Since the mount on the zoom doesn't rotate when focusing, it might be possible to make a PL adapter for whole system. The zoom slips into the attachment even deeper than the NASs. Using that with other lenses would be even more of a problem.
---LV
#5 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
Posted 08 December 2005 - 04:38 AM
Thanks Leo,
How close is the Konvas 1M mount to the Arri standard. Can I make it fit with a little milling or would I have to have a plate made to replace the turret?
#6 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 08 December 2005 - 04:38 PM
The 1M mount (OST-18) has a flange depth of 57mm and a diameter of 47mm, which copares to the Arri st. mount's 52mm flange depth and diameter of 41mm.
One can get PL adaptors for zooms:
http://cgi.ebay.com/...1QQcmdZViewItem
I once saw an Australian built Pl adaptor for the primes. That was some time ago.
Google Steve Morton in Australia. He was probably involved.
Also it's possible to remove the anamorphic section of round fronts. Steve Morton would also know about that.
---LV
#7 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 20 December 2005 - 12:39 PM
The many russian long prime anamoprhic lenses have two versions spherical and anamoprhic.
they take spherical lens and add rear anamoprhic adapter and have anamoprhic lens.
From other side, this idea work good with tele lenses and some zoom lenses, the wide lenses use
front anamorphic adapters, because, the distence between rear glass and mirror inside camera very short for wide lenses and set rear anamoprhic adapter not possible.
And, the front anamorphic adapter widen of angle of lens.
I make a some experimens with front anamoprhic adapter and zoom lens of Krasnogorsk-3 camera,
have good result.
But, from my expience, the better use full factory made anamorphic prime or zoom lens.
#8 Antonio Campos
Antonio Campos
  • 6 posts
Posted 16 June 2007 - 11:02 AM
Do you have any more info on Theirry Tronchet- on how his system works and how to contact him? I have googled with no luck...thanks very much
#9 Christian Appelt
Christian Appelt
  • 470 posts
Posted 17 June 2007 - 04:06 PM
Paul,
any conversion of anamorphic front adaptors to your existing spherical lens will definitely cost you more than buying a complete Foton-A adapter+zoom lens 37-140mm. Now and then you can find such a lens in OCT-18 mount on eBay or from the known & trustworthy sellers for US$ 750-900. That will give you a decent basic lens and a very good anamorphic adapter - with mechanical coupling for easy focus pulling.
Take off the attachment and you can shoot spherical too.
You could buy a single Foton-A attachment and use it in front of your existing lens, but then you have to do double focusing - not to everyone's taste... ;)
Edited by Christian Appelt, 17 June 2007 - 04:08 PM.
