35mm lens for 16mm camera
31 replies to this topic
#1 BradH
BradH
Posted 30 November 2005 - 12:58 AM
Can anyone explain what the problem is with modifying my K-3 camera (or any 16mm camera) lens mount to fit a 35mm still camera lens to allow me to use many lower cost highly available stll camera lenses? I have a Canon EOS 35-80mm lens and a 100-300mm lens. The EOS lens's will need to come very close to the shutter in order to work, but I think it will fit if I create a new front plate that the lens mounts to.
Maybe my queation should be...what's the difference between a movie camera lens (16mm) and a still camera lens (35mm) besides the projection size and focal lengths? The difference between T-stop and F-stop seems negligible to me when shooting 16mm film.
I'm assuming I can create a new front lens mounting plate for my K-3 to fit an EOS lens at the correct focal distance, deal with the larger 35mm projection size, and deal with the lens focal lengths through tests and experience. Am I missing something?
BradH
#2 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 30 November 2005 - 12:50 PM
Hi- I think the only real issue is finding 35 lenses wide enough to give you wide angle that works with 16mm (like in the 8-10mm range.) I know some of the super-wide still lenses have back elements that jut quite aways into the camera (some require a mirror lock-up) and would smack into your shutter.
A nice trend though is happening with lenses designed for digital SLRs, with zooms appearing now in the 10-30mm range, which would cover 16mm nicely. A set of nice, relatively inexpensive wide primes designed for a digital SLR (I can dream, can't I?) would be great to adapt to a 16mm camera-
#3 Ian Marks
Ian Marks
Posted 30 November 2005 - 01:25 PM
People use 35mm still camera lenses on 16mm movie cameras all the time, so basically there is no great problem. There are some things to bear in mind. Obviously, a 50mm "normal" lens on a 35mm SLR still camera becomes a telephoto lens on your 16mm movie camera. You need to use a 24mm wide angle lens to approximate a "normal" 25mm lens on a 16mm camera (and I think a focal length of about 16-17mm should be considered normal for 16mm). The lenses you mention in your post are all going to be in the telephoto range, obviously.
The aperture rings of most still camera lenses have a strong detent at each F-stop (or half F-stop), which makes changes during a shot a problem. Also, the focusing rings don't have as much "travel" as most lenses intended for MP use, and some older lenses may develop some "slop" in their focusing, or start to feel "dry" as they lose their lubricant. These may not be a problem for a casual stills shooter, but definitely make it difficult to follow focus during a shot. Finally, lenses that are mass produced and machine assembled are simply not made with the same precision as a high quality motion picture lens.
The T-stop/F-stop difference is not much of an issue when using fixed focal length lenses. However, there are very few 35mm still camera zooms I would consider using for 16mm, especially considering how many high quality fixed focal length lenses are available on the used market. As you know, the Krasnagorsk has a standard M/42 "Pentax" lens mount, which means there are literally of thousands of lenses that will go straight onto your camera with no fuss (and no need to fabricate a new front). For a wide angle, consider using the Peleng 8mm.
All of that having been said, if there is one line of still camera lenses I would never consider adapting for 16mm motion picture use, it's the Canon EOS lenses. Am I bashing Canon? No way - I have a set of FD lenses for use with my ACL and I think they're great. The problem with the EOS lenses? No aperture ring!
#4 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 30 November 2005 - 04:47 PM
What about the Zenitar 16mm 2.8? Is that lens worth getting for a K-3? What would be the focal length equivilent? something like 30mm?? I see them on ebay and am concidering a purchase along with the Peleng.
chris
#5 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 30 November 2005 - 10:15 PM
What about the Zenitar 16mm 2.8? What would be the focal length equivilent?
A 16mm lens on a 35mm camera is still a 16mm lens on a 16mm camera.
The lens focal length doesn't change when you put it on a different piece of gear.
#6 Chris Burke
Chris Burke
  • 1720 posts
  • Boston, MA
Posted 01 December 2005 - 03:56 PM
This is the opposite of what I always thought. That being that say a 25mm lens on a super 16 camera is equal to a 50mm standard lens on a 35.
#7 Andy Sparaco SOC
Andy Sparaco SOC
  • 203 posts
  • Chicago and most airline lounges
Posted 01 December 2005 - 05:18 PM
The focal length does not change but the coverage of the lens does.
All lenses project a circular image
Different lens designs project different size images
You can have two lenses of the same focal lengths which do not deliver the same image size
A lens designed for 16mm will not cover a 35mm frame
A lens designed for 35mm will cover cover both 35mm and 16mm
But since the 35mm frame is larger then 16mm you see more of what that lens is seeing, which is lost because the 16mm just does not have the physical real estate to capture the image.
You are seeing twice the magnification on the 16mm frame but with half the resolution of the 35mm frame.
It is very common to own a set of 35mm lenses from 18mm and longer which are used for 35/16mm then have three additional 16mm lenses to cover the wide end of 16mm. 16mm/12mm/9.5mm. Why not just use really wide 35mm lenses? -because they get real expensive to deliver coverage with such a wide angle-optical gymnatics cost big $$$$$
Cooke just added two new lenses to the "S" line of primes which do just that.
Edited by asparaco, 01 December 2005 - 05:19 PM.
#8 David Mullen ASC
  • 20072 posts
Posted 01 December 2005 - 06:13 PM
A 25mm lens on a 16mm camera has the same field of view as a 50mm lens on a 35mm camera -- but it is still a 25mm lens on either camera. It just behaves more wide-angle on a larger format, more telephoto on a smaller format. But the focal length is the focal length is the focal length -- it's still a 25mm lens when it's on a Super-8 camera or an IMAX camera or on your 35mm still camera. It just won't get you the same perspective.
#9 BradH
BradH
Posted 02 December 2005 - 12:21 AM
OK. I was mainly looking at the 35mm still lenses for telephoto shots. But I guess it would be easier and probably ultimately cheaper to buy m42 mount lenses at the same focal lengths rather than use what I have (Canon) and make a new front plate.
At the wide-angle side it's not so clear to me though. Wouldn't a 35mm camera lens like the Peleng 8mm on a 16mm camera give me essentially a 16mm shot? If so, what does that give me that the 17mm-69mm lens at 17mm (that came with the K-3) doesn't? Doesn't the Peleng 8mm have that distorted fisheye look? I don't see a use for that with traditional shots. Are all 8mm lenses going to have that look? If so it sounds like I can't get lower than my 17mm-69mm using a 35mm camera lens. What's the widest angle 16mm camera lens I can get without getting the distorted fisheye look?
Brad
#10 David Mullen ASC
  • 20072 posts
Posted 02 December 2005 - 12:49 AM
I don't think you understood what we just said. An 8mm is an 8mm on any camera, so yes, an 8mm on a 16mm camera would look like a 16mm on a 35mm camera -- but that also means that a 17mm-69mm zoom on a 16mm camera would look like a 34mm-138mm zoom on a 35mm camera. In other words, the Peleng 8mm is twice as wide-angle as the 17mm end of the zoom, no matter what camera format it is used for.
A 17mm-69mm zoom on a 16mm camera would not start at a much of a wide-angle.
An 8mm lens would be super wide-angle on a 35mm camera but only moderately wide-angle on a 16mm camera, so it would not look as distorted. It is not unusual to use 8mm lenses in 16mm for wide-angle effects. Like you said, it's like using a 16mm lens in 35mm.
Often people use the Zeiss lenses made for 16mm, so in that set, a 9.8mm and 12mm were your basic wide-angle primes often used. The 9.8mm can vignette in Super-16, so one alternative is the 8mm Optex.
Common Super-16 zooms are the 11-110mm Zeiss, 8-64mm Canon, maybe the 11-138mm Canon.
Anyway, this is all to suggest that a typical wide-angle shot in 16mm would be in the 8mm to 12mm range, so you may feel a little restricted if your widest lens starts at 17mm.
#11 BradH
BradH
Posted 02 December 2005 - 09:09 PM
I think I've got it now. I think I missuse focal length when I mean field of view. Thanks for the help!
Brad
#12 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 03 December 2005 - 12:56 AM
chris
I just bought a Zenitar 16mm from Russia (man, its still weird getting something from there) and it gives a great wide view. The problem is there isn't a fully manual setting for the aperature so you have to wedge in the pin somehow to be able to change the F-Stops manually. I hate to have to "break" it to work properly.
The other issue is lack of a standard filter mount. It comes with 3 filters, a green, red and yellow filter but I wish I could get an 85 for it.
#13 jeremy edge
jeremy edge
Posted 03 December 2005 - 01:15 PM
To lock the pin in...get a fountain pin and push it inside the body and let it snap to one side so it is held inside the lens.
The Zenitar is not sharp wide open and you may get chromatic abberations. use it at 5.6 to 11 if you can.
There is no 85 filter that I know of for it.best to use daylight stock for the daylight shots.
#14 BradH
BradH
Posted 03 December 2005 - 01:25 PM
Will that lens (Zenitar) cover super16 at 16mm?
#15 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 03 December 2005 - 01:40 PM
Its a 35mm still camera lens it will cover with ease.
Stephen
#16 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 03 December 2005 - 10:06 PM
I undersand that the central part of that lens is relativly free of distortion WHEN you are onlyusing the 16mm Movie frame part of the field. If you put it on a 35mm still Camera, you use more of the field and it is distorted. Note that even the 17mm Metor Zoom I understand will not fit a 35mm PENTAX camera as it sticks out quite a bit into the area that holds the mirror on the pentax. It is also designed to only cover the 16mm Movie frame. (a problem for folks who have converted their K-3 to Super16- they have to avoid using the lens at very wide angle settings.)
#17 Ian Marks
Ian Marks
Posted 05 December 2005 - 02:37 PM
I've seen 16mm some footage shot with the Peleng 8mm. It had some noticeable barrel distortion out at the corners, but did not have the fisheye "look" ... it was actually quite nice. I think by composing thoughtfully (and possibly by avoiding scenes with lots of straight lines, which would be a tip-off) one could use it as a wide angle very effectively. It's certainly attractively priced. I understand that it does not come with an 85 filter, and with its protruding front element one would have to jerry rig some kind of filter holder (maybe a clamp-on to Series 9) to provide for filtration.
#18 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 06 December 2005 - 01:44 PM
I think the Peleng 8mm looks horrid in 16/S-16. Lots of distortionand weak contrast. It looks great in 35mm/s-35, where it is a wonderful fisheye effect lens. It is extremely limited in use but it really is an effects lens, just like a 5.7mm Kinoptik in 16 is only good as a music video/dream sequence lens. If you want a "normal" looking lens that is also quite wide, then go for an Optar, Elite or Optex 8mm. These lenses look great in S-16, but they are also much more expensive.
The Peleng would never be covered by a Series 9. I doubt that a 138mm would properly cover. More likely at least a 6x6 would be required.
#19 Ian Marks
Ian Marks
Posted 06 December 2005 - 02:10 PM
"I think the Peleng 8mm looks horrid in 16/S-16. Lots of distortion and weak contrast. It looks great in 35mm/s-35, where it is a wonderful fisheye effect lens. It is extremely limited in use but it really is an effects lens, just like a 5.7mm Kinoptik in 16 is only good as a music video/dream sequence lens. If you want a "normal" looking lens that is also quite wide, then go for an Optar, Elite or Optex 8mm. These lenses look great in S-16, but they are also much more expensive."
I suspect that the quality control on the Peleng is not great, and there might be a lot of variation from lens to lens. I can only say that the stuff I saw looked pretty nice - no contrast issues that I was aware of, but then I don't know how it might have been tweaked in the transfer. Definitely NOT an ideal wide angle lens, in that it's not designed to render straight lines straight, but we're talking about a sub-$200 lens here. Of course the Optar/Elite/Optex lenses are better, but you're probably not going to see one fitted to a K-3. As for the 5.7 being good only for effects, I disagree. Of couse, if you start swinging it around during a shot, things start looking pretty wild. There's a wide-angle tracking shot through a hospital in ubrick's "Clockwork Orange" (done, I believe, with the 9.8 Kinoptik on 35mm) which I think looks great, and I do like the stuff shot with the 5.7 in "El Mariachi." It's all subjective, of course.
#20 Scott Bullock
Scott Bullock
  • 245 posts
  • Denver, CO
Posted 27 December 2005 - 10:09 PM
First of all, I'm a newbie here so please go soft on me for now. Secondly, this is a wonderful discussion that applies to me so when I saw it in cyberspace I just had to join in. (I'm sure I'll be posting in many other topics as well, but I need to surf the other topics a little more thoroughly first so as not to be repetitive.) Finally, I can't believe it took me so long to find this site . . . I must have the web surfing skills of a tortoise!
As to the discussion at hand, I have a little bit of knowledge on the subject but am still seeking plenty more. To wit, I have an Eclair NPR that was converted to S16 and I just acquired a C-mount to Nikon adapter and also a C to Canon FD adapter, as well. I did this mainly because the adapters are cheap as dirt and I already own a good assortment of Nikkor and Canon 35mm still lenses -- all primes, ranging from 14mm to 135mm. In fact, I think I have every common focal length between the two. I've yet to do any real testing with this set-up, but I was hoping to get some feedback on what to expect if/or when I attempt to blowup my images to 35mm. I don't expect to get the same results that I would if using Optar Illuminas or Zeiss Super Speeds, but am I going to be completely horrified and have to run out of the screening room in order to puke, or otherwise hugely disappointed? (Certainly these 35mm still primes have to be better than using an Angenieux 15 - 150mm, don't they?) Or, will the results be acceptable should such a need arise on a particular project?
I already understand the limitations of trying to use such lenses for wide-angle work (because there is a decided lack of "wide-angle" 35mm still lenses out there), but what about the slower speeds (f/2.8, 3.5, 4) of these lenses? Am I going to have to shoot all my interior night stuff wide-open with 500 ASA film? Speaking of wide-angle lenses, is the angle-of-view on a 14mm or 17mm lens going to be adequate enough for most applications in the S16 format, especially for interiors, or am I constantly going to be looking for something wider? If so, what opinions are there regarding - gasp - the uses of "quality" wide-angle adapters to increase AoV? (I do see that digital SLR lenses are becoming increasingly wider, but I have very little familiarity with them in terms of quality.)
Okay, that is a lot of questions, so I will stop for now even though I have many more, like the best way of calculating depth-of-field when shooting S16 and using 35mm still lenses: Are there charts available? Or will I have to critically focus every shot? Any and all responses are greatly appreciated. Sorry for such a longwinded initial post . . . :unsure:
