Both 24fps/50Hz AND 24fps/60Hz options?
#1 Marcus Frakes
Marcus Frakes
  • 40 posts
Posted 12 December 2005 - 07:06 PM
OK Why are there two speed options (50Hz & 60Hz) on my motor settings for 24fps? Isn't 24 = 24 in any math class? You can't change shutter angle by the flip of a switch. Is this only for a pilot tone running OUT to an audio recorder or something to do with powering from an AC source? I always use clapper boards so from what I can see, I could use either setting since they are "identical"??
#2 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 12 December 2005 - 08:38 PM
It must the power supply selection. What camera are you using ?
If you are in US it's 60 Hz, if you are in Europe, it's 50 Hz
#3 Marcus Frakes
Marcus Frakes
  • 40 posts
Posted 13 December 2005 - 03:17 AM
It's an Eclair NPR and runs off a battery. So it wouldn't know if I'm filming in Paris or Chicago. As I see it, either setting won't change the motor speed or any internal camera frequency. Both the Perfectone and Bela motors have this setting.
Edited by Montage, 13 December 2005 - 03:19 AM.
#4 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 13 December 2005 - 03:58 PM
You run on batteries, OK, but the motor could be supplied through the AC current, as well, so I guess this is why (Paris, Texas, wouldn't be the same as Paris France, BTW... ;) )
#5 Dirk DeJonghe
Dirk DeJonghe
  • 612 posts
  • Kortrijk,Belgium
Posted 13 December 2005 - 11:22 PM
Probably the pilotone output to Nagra recorder.
