Put a sticker on my camera- must get goo off
13 replies to this topic
#1 JonathanSheneman
JonathanSheneman
Posted 12 December 2005 - 09:34 PM
I put a kodak sticker on the side of my K3 - I've since removed but the area still has gooey residue on the surface (surface has tiny bubbley relief). What solvent can I use to remove all residue? Thanks.
#2 Trevor Greenfield
Trevor Greenfield
  • 162 posts
  • North Idaho
Posted 12 December 2005 - 10:32 PM
Rubbing Alcohol?
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 12 December 2005 - 10:56 PM
In the US there are products like Goo-Gone and Goof-Off that are citrus based and do an excellent job of removing such residue without causing damage. They are available from places such as Home Depot or Lowes. I use them to clean shipping labels off my cases .
#4 LovinItAll
LovinItAll
  • 9 posts
Posted 13 December 2005 - 09:02 AM
WD-40 works miracles! Put a little on a cotton rag and the "goo" will wipe right off.
Acetone or lighter fluid also work.
#5 Preston Herrick
Preston Herrick
  • 89 posts
  • Washington
Posted 13 December 2005 - 11:59 AM
Use Goo-Gone. Good stuff for a variety of goo removal. Goof-off is a much stronger petroleum based solvent. I used it to remove undercoating on my project car.
#6 Daniel Stigler
Daniel Stigler
  • 177 posts
  • Berlin, Germany
Posted 13 December 2005 - 01:58 PM
Acetone is very agressive and will also remove or at least damage the paint. WD40 is a much better choice.
#7 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 13 December 2005 - 04:08 PM
Try heating the goo with a hair-dryer and rubbing it off with a soft but non-disintegrating object.
Hands work, but it can be painful!
#8 Trevor Greenfield
Trevor Greenfield
  • 162 posts
  • North Idaho
Posted 13 December 2005 - 09:07 PM
The heat may not be such a good idea because the bumpy covering they used on the sides of the K3 is held on with glue... and glue is not one of the Russian's strong points.
#9 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 14 December 2005 - 01:30 AM
Use Goo-Gone.
#10 Mark Wilson
Mark Wilson
  • 28 posts
Posted 14 December 2005 - 02:22 AM
Pure peppermint oil is excellent and doesn't normally attack paint, smells pretty good, and a couple of drops on a handkerchief will do wonders for a blocked nose too :)
This is particularly recommended for getting adhesive goo off Perspex (Lucite) and similar shiny plastic surfaces.
Eucalyptus oil is cheaper but it isn't as fast-acting, although it will also do the job.
#11 Mike Crane
Mike Crane
  • 141 posts
Posted 16 December 2005 - 11:47 PM
Use some sulfuric acid and sand paper. Works wonders. :lol:
#12 JonathanSheneman
JonathanSheneman
Posted 19 December 2005 - 10:13 PM
You know what Mr.Crane? Thanks for ruining my camera and my life. I tried your suggestion of sulfuric acid and sandpaper thinking that it might work and it did I guess but it also burned a hole through the side of my camera plus I now have severe 3rd degree burns on my hands. :(
I guess I could have read the other posts or realized that happy smile on the end of your post might have meant you where joking but should I have to?
You f-cked me bad Mr.Crane.
#13 LovinItAll
LovinItAll
  • 9 posts
Posted 24 December 2005 - 01:34 PM
I assume this was a joke, too. No one in their right mind would break out a bottle of sulfuric acid and start working on their camera body.
Seriously, Goo-B-Gone (or whatever you call it - I have used various "goo removers") is okay, but WD-40 is BY FAR the best substance I have ever used to remove sticker residue. Great for removing "permanent markers" like Sharpies, too (assuming the markings are on some type of plastic or glass).
Don't use it for a "personal lubricant", though. The fumes ruin the mood! :)
#14 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 28 December 2005 - 11:36 AM
[Seriously, Goo-B-Gone (or whatever you call it - I have used various "goo removers") is okay, but WD-40 is BY FAR the best substance I have ever used to remove sticker residue. Great for removing "permanent markers" like Sharpies, too (assuming the markings are on some type of plastic or glass].
I've been using mineral spirits for years to take tape and sticker residue off of equipment. It works slower than Goo-B-Gone (and 3m's equivalent product) but is safe on most materials and slow can very much be a virtue working with valuable gear. If the residue is real old and hard, I soak a couple layers of cotton cloth with mineral spirits and let it sit on the residue for a while, even putting a piece of aluminum foil over that to keep it from drying out. I've used this technique extensively on high-dollar test equipment that makes film and video gear look cheap!
