Super 35, Anamorphic, etc...
#1 Sean Azze
Sean Azze
  • 145 posts
  • P.A.
Posted 14 December 2005 - 09:53 PM
Hey
Wanted to know if someone could either visually demonstrate to me or give me a link to a site that specifies what the differences are in terms of aspect ratio between Super 35, anamorphic, 1.85:1, etc.
I've had this subject explained to me in words, but must admit that I still don't have a clear understanding of what the differences are.
#2 Trevor Greenfield
Trevor Greenfield
  • 162 posts
  • North Idaho
Posted 14 December 2005 - 10:18 PM
These might help:
http://en.wikipedia....t_ratio_(image)
another: http://members.shaw....ther/aspint.htm
and one more: http://www.geocities...303/aspect.html
#3 David Mullen ASC
Posted 15 December 2005 - 12:28 AM
Super-35 doesn't really have one aspect ratio -- it's a method of shooting to get different aspect ratios.
Basically it comes down to the fact that 35mm theatrical projection, for the most part, now comes in two types: matted widescreen and anamorphic widescreen. In matted widescreen, the old 1.37 : 1 Academy format is further masked by the projector gate top & bottom to look more rectangular -- usually the amount of masking or matting is to 1.85 : 1.
In anamorphic widescreen, or "scope" (short for CinemaScope) the image on the print has a 2X horizontal squeeze which is unsqueezed by an anamorphic lens on the projector. Current standard for the unsqueezed image is 2.39 : 1 (sometimes called 2.35 or 2.40.)
Two common methods of achieving a 35mm scope print is to either shoot with 2X anamorphic camera lenses, or to shoot with spherical lenses in Super-35 and frame for cropping in post to 2.39, and then squeezing it to anamorphic. Super-35 just means exposing Full Aperture -- the whole width of the 35mm negative from sprocket row to sprocket row -- rather than not using the small area on the left side of the frame reserved for the optical soundtrack. So Super-35 is not a release print format since it does not have room to put a soundtrack anywhere if you simply made a contact print off of the negative.
But you can frame other aspect ratios in Super-35. 4-perf 35mm Super-35, if you use the whole negative area both across and top to bottom has a 1.33 : 1 aspect ratio, so you waste quite a bit cropping to 2.39 : 1. Some people frame for cropping to 1.85 : 1, and others for cropping to 1.78 (16x9) for transfer to 16x9 video.
If you shoot 3-perf Super-35, then Full Aperture is already about 1.78 : 1 (16x9), so you waste less when cropping to 1.85 and 2.39.
This is from my book Cinematography:
The black band on the left side is the soundtrack area. "A" would also be 4-perf Super-35 Full Aperture. You'll note that "D" for CinemaScope looks almost square but remember that the image on it has a 2X squeeze, so becomes doubled in width when projected with an anamorphic lens.
#4 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 15 December 2005 - 01:08 PM
Hey
Hey
---Not sure what happened there.
Try the Widescreenmuseum site:
the entrance page:
http://widescreenmuseum.com/
aspect ratios:
http://widescreenmus...n/apertures.htm
Though there isn't much about Super 35, It's more concerned with the older version SuperScope.
---LV
#5 Eric Steelberg ASC
Eric Steelberg ASC
  • 538 posts
Posted 15 December 2005 - 02:41 PM
Panavision's website is also complete with the info:
http://www.panavisio...spect_ratio.php
