60FPS transfer to SD
#1 EvanSchafer
EvanSchafer
  • 5 posts
  • Asheville, NC
Posted 15 December 2005 - 09:43 AM
Hey all-
We are bidding a job to be shot with the VariCam and possibly transferred to DVCPRO50 for post. I just want to confirm that it is possible to transfer material that was shot at 60FPS and that it would be extractable from the SD dubs by Final Cut. Anything I need to know or take into consideration?
Posted 15 December 2005 - 12:07 PM
Hey all-
Yes, you have to decide if the 60P material is to be played back as slo-mo, like in a 24 fps timeline, or if it to be converted to 60i as normal motion, where each P frame just gets turned into a field.
#3 EvanSchafer
EvanSchafer
  • 5 posts
  • Asheville, NC
Posted 15 December 2005 - 01:13 PM
Good point. It would be slo-mo. I found this article over on 2-pop, (actually, you posted on it David) which explains the process. I would have to digitize the material at full rez, use the frame rate converter and then output to a DVCPRO50 deck then digitize that material. Not exactly a quick work around but do-able.
Here's the link if anyone else is interested:
http://www.uemforums...=5&o=&fpart=all
