Panavision Anamoprhic CF primos
#1 Arni Heimir
Arni Heimir
  • 326 posts
  • Reykjavik/Barcelona
Posted 17 December 2005 - 09:30 AM
Are the Panavision Anamorphic Close Focus primos as color matched as panavision assumes? Has anyone used them and how was the color grading experiance/process in post?
Are the Hawk V-series better color matched? Any comments?
Edited by arnih, 17 December 2005 - 09:31 AM.
#2 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 17 December 2005 - 10:22 AM
Both are modern lenses, manufactured to very high tolerances, just like spherical Primos, Zeiss MasterPrimes, Ultraprimes and Cooke S4s so I seriously doubt there will be any noticeable difference in color.
#3 David Mullen ASC
Posted 17 December 2005 - 10:32 AM
Yes, color-matching really isn't a problem with modern line-up of primes in a series.
When I shoot with Primo anamorphics, I usually make the 75mm a Close-Focus, because this tends to be the lens I default to for those classic "dolly into a tight close-up" moves. You can do that with a regular 75mm Primo anamorphic but you tend to always bump into minimum focus.
Edited by David Mullen, 17 December 2005 - 10:32 AM.
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 17 December 2005 - 10:56 AM
Yeah, the 75mm seems to be the lens where good close-focus is most important. It is a lens that is wide, but still it doesn't distort too much if you move close into someone's face.
