DE vs. SE HMI's
14 replies to this topic
#1 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 20 December 2005 - 04:25 PM
Anybody have any suggestions when buying older DE HMI fixtures?
Should I 'just say no' to double-ended, or are they still fine if they're cheap to buy?
#2 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 23 December 2005 - 01:14 AM
DE HMI's are fine on Fresnel Heads, Great soft light output. If you go with Pars, then you will want to go with SE HMI's. You can find DE HMI's heads pretty cheap at Pyramid Films in CA.
Hope this helps.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 24 December 2005 - 12:16 AM
You may find great difficulty getting replacement bulbs, and those bulbs will be at a premium. Also, the less efficient design means less light for the same wattage.
#4 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 24 December 2005 - 12:19 PM
There is no difficuty getting DE replacement bulbs, you can buy them anywhere and they are less expensive then the SE bulbs. Also, they are not less efficient . The reason you think they are is because DE globes are used more in Fresnel Heads which the output is less because of the fresnel lens and you think that a SE lamp is more efficient because when used in a Par there is no fresnel lens so you got more output light (no losses).
#5 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 26 December 2005 - 05:28 AM
Hey now,
Don't forget dichroic PAR 64s. No flicker hassles and the highest output per watt. You can get the theatre cans at Dr. Bob's for around $40.00. 1000W Globes are about $150.00 at 5200K at Mole Richardson.
#6 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 28 December 2005 - 01:28 AM
You're welcome Tim.
#7 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 28 December 2005 - 12:33 PM
You're welcome Tim.
Well thanks, Gilbert. You're welcome too.
Please shorten your signature to 4 or 5 lines of text please.
#8 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 28 December 2005 - 11:44 PM
No thanks Tim.
I like my signature just the way it is. If it was ment to be only 4 or 5 lines of text, then thats all you should be able to write in the signiture section of the control panel, 4 or 5 lines of text. Right? So stop playing GOD.
#9 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 29 December 2005 - 12:00 AM
Please note the forum guidelines:
"Signatures may contain images, but may not be any larger than 300x100. If your signature is larger than the allotted size given or deemed unacceptable by staff, you will be requested by a moderator to resize or change your image. Please also try and keep text signatures under 5 lines. Failing to comply with a moderator's request to fix your signature will result in the removal of your signature. "
#10 JoseM.
JoseM.
  • 1 posts
Posted 29 December 2005 - 12:05 AM
Hey Tim,
I have been noticing alot too how you try to play GOD!
Your not GOD! If You want to change the rules then you should limit what you can write on the control panel!
Jose Miramontez
#11 Gilbert
Gilbert
  • 31 posts
  • hmi@usa.com
Posted 29 December 2005 - 12:12 AM
Tim, now whats wrong with my image size? I believe it is alot less then 300X100, so why are you bringing that up?
#12 Tim Tyler
Tim Tyler
    Administrator
  • Admin
  • 1295 posts
  • Olympia, WA (US)
Posted 29 December 2005 - 12:15 AM
Really?
Funny how the email address you registered under is 'hmilighting@hot****.com' and that you're posting from the same IP as Gilbert Navarro. Might you be the same person??
#13 Mike Williamson
Mike Williamson
  • 534 posts
Posted 29 December 2005 - 12:16 AM
No thanks Tim.
Seems like a pretty reasonable request, Gilbert, so what's the problem? Maybe you think Tim should be subsidizing the advertising for your company?
#14 Rod Otaviano
Rod Otaviano
  • 185 posts
Posted 29 December 2005 - 12:48 AM
Hey Tim,
Jose Miramontez
He's not playing God, just trying to keep the forum organized and clean. The problem with this kind of signature is that it creates visual pollution and makes reading the posts a harder task.
#15 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 29 December 2005 - 12:11 PM
Tim's actually been one of the most laid back and even-keeled moderators I've experienced. This forum is a great asset, let's try to keep things civilized. If someone asks for a bit of advice, it is not absolutely necessary for them to thank you for information. And if a foum moderator makes a direct request then it is a good idea to try to accomodate it. Beyond everything else this is just good manners.
