video out to ENG viewfinder
#1 Jan Doggen
Jan Doggen
  • 26 posts
Posted 21 December 2005 - 04:25 PM
I am looking for a way to connect an ENG viewfinder to the video-out of a vx2000/pd150 or dvx100 camcorder. (I know there is an adapterbox for the canon xl1 but i am not interested in that.)
I wonder if anyone can get me clued up about this.
If I find the pinout of a viewfinder-connector, will getting 12v into it (i know most viewfinders need 12v) and connecting the video-out to the right pins actually work? Or is some kind of signal conversion needed?
thanks for any info on this...
JD
#2 Phil Rhodes
  • 12172 posts
Posted 21 December 2005 - 04:39 PM
Yes, it's usually just power and video - the other pins are things like the tally light and any internal warning lights. There may be other video-related signals, such as peaking or graphics overlays, but I've never seen one that wouldn't just take a normal video input and display it.
You should try to feed the viewfinder from the Y component of a Y/C output, which will avoid your seeing composite colour encoding artifacts all over it.
Phil
#3 Jan Doggen
Jan Doggen
  • 26 posts
Posted 22 December 2005 - 10:27 AM
Phil
S-Video outputs are Y/C, right?
You know, I hadn't even thought about using the s-video output...
Might there be problems with the levels and/or impedance of an s-video output?
I guess I should just get a second-hand viewfinder and try to hook it up.
Jan
#4 Phil Rhodes
  • 12172 posts
Posted 22 December 2005 - 02:27 PM
Yes.
Well, it's probably the only way you have of getting a proper monochrome feed. You could use the composite output, but you'd see crawling dots all over it.
Not in my experience.
Phil
