Difference between Arri standard and bayonet
#1 3ldfilms
3ldfilms
Posted 05 January 2006 - 08:01 PM
Can someone describe the difference between an Arri bayonet and standard mount. Being primarily a director I have not paid much attention to the mounts in the past, but I just got a Super 16 K-3 with crystal motor and Arri standard mount.
I'm looking to get a couple of extra lenses. Can one get adapter between bayonet and standard?
#2 Mike Welle
Mike Welle
  • 125 posts
Posted 05 January 2006 - 08:27 PM
An Arri Bayonet mount lens like the Optar Illuminas I have, has two little metal parts which protrude out of it on opposite ends (its easier to show a picture than describe it.) On my ACL they go into an adapter that has room for these two parts. The adapter which I got from Les Bosher, has a locking mechanism to hold the lens in place.
I used to have an Arri Standard lens, the Angenieux 10-150. It didn't have the metal parts jutting out of the side, but went into the mount straight, and you would tighten it up once it was seated in the hole.
Here are a couple of links which give much more lucid descriptions of these mounts:
http://www.cinematec.../arri_16bl.html
Look under lens mount.
Also try:
http://www.rondexter..._and_mounts.htm
Hope this helps,
Mike
#3 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 06 January 2006 - 01:44 PM
---NO. A standard mount lens will fit in a bayonet camera mount, but not the other way around. Both mounts have the same flange depth and diameter. The two nobs on the bayonet give the lens a more secure grip, but prevent the bayonet mount from going into the standard recepticle.
---LV
#4 Mark Dunn
Mark Dunn
  • 2670 posts
Posted 07 January 2006 - 12:14 PM
Are you sure it's an Arri Standard mount? My K3 has a bayonet but I think it's proprietary. The flange focal depth and mount diameter don't seem right.
#5 3ldfilms
3ldfilms
Posted 07 January 2006 - 12:20 PM
When Du-All does there upgrade they also switch the mount to Arri Standard which is both a blessing and a curse. I have a couple of Pentax Super Takumar lenses that are great on K3s (even though they are 35mm still lenses) that I can't use any more.
Ed
