Devry 35mm camera
#1 dd3stp233
dd3stp233
  • 102 posts
Posted 08 January 2006 - 12:03 AM
Hello, I have a 1926 Devry 35mm "standard" Model A "lunchbox" motion picture camera. I've searched the internet and there is little information available on this camera. I am planning to shot with this camera soon and wanted to know if anyone could tell me what the shutter angle is for it? (Much easier then taking it apart to measure it). For those of you who aren't familar with this camera, it is one of the smallest 35mm movie cameras I have ever seen. It is the same size as childs lunchbox. Holds an internal 100ft spool of film and is spring driven (55ft on one full wind at 18fps). It can also be handcranked, there is a crank port in the side. Has two viewfinders (non-reflex) with an optional third which actually would be reflex through the lens or filmbase? Neat old camera.
#2 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 08 January 2006 - 11:39 AM
Can you not see the shutter through the lens port, maybe trace the shutter sector and measure the angle? Or photograph the shutter and measure on your monitor. Or guess at 180deg.
#3 dd3stp233
dd3stp233
  • 102 posts
Posted 08 January 2006 - 02:07 PM
The lens port is rather small (about 32mm across) and so I can not see much of the shutter blade. The best I can make out is that it is less then 180 degrees and more then 90. I just wondering if some else already had this info. I don't like guessing when figuring out exposures so an exact measurment of the angle is what I need. If someone has the owners manual for one of these cameras, it should be listed in it.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 08 January 2006 - 02:18 PM
If you go with 135 you will be very close enough!
Stephen
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 10 January 2006 - 03:10 PM
---Ain't the internet swell. One can find anything one wants, as long as it's in an ad.
The 2nd edition of the 'American Cinematographer Hand Book and Reference Guide' 1938 lists the Devry Standard Model A as having a '130 degree, fixed position, no dissolve'.
The Magic Eye Model A has '90 degrees, adjustable, no dissolve'. It's adjustable for stills. 1/100-1/1000 of a second.
---LV
#6 dd3stp233
dd3stp233
  • 102 posts
Posted 10 January 2006 - 04:22 PM
---LV
Thanks Leo, thats what I needed to know.
#7 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 17 January 2006 - 09:50 AM
now I wonder which model DeVry I have is, as it has a 45 degree angle shutter.
