calculate sensitivity to set...
#1 Michael Althaus
Michael Althaus
  • 57 posts
  • Santa Monica / Switzerland
Posted 10 January 2006 - 04:23 AM
How do you usually calculate the sensitivity to set if a filter cuts 1/x of a stop. I mean, if I have a 400 ASA film and a filter I use takes 1/3 of a stop then I know that I have to set the filmspeed to 320. The math for this would be: 200 x 2^(2/3), right? Isn't there an easier way to do calculate it? I hope you understand what I mean, sorry for my lack of English....
Regards,
Michael
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 10 January 2006 - 04:47 AM
Regards,
Michael
Keep things simple, take a reading then open by 1/3 stop!
Stephen
#3 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 10 January 2006 - 10:31 AM
Since your starting point is "what value is 1/3 of a stop under 400 ?", the logical way to calculate this would have been 400/2^(1/3)
But it is also true to say that the correct result is 2/3 of stop over 200 ASA and therefore your calculus is good.
Since you know that 2^(1/3) = 1.25, you can just remember the series : 100, 125, 160, 200 etc. and multiply these figures by whatever factor you like to get the values you're looking for. For instance : 200, 250, 320, 400 are also the values by 1/3 of a stop steps...
Look at your light meter you will see the sensitivity values are in that order
#4 Danish Puthan Valiyandi
  • 11 posts
  • Germany
Posted 10 January 2006 - 06:06 PM
Michael,
look here http://en.wikipedia....wiki/Film_speed to get a list of the most common film speeds.
Each step equals a 1/3 stop.
Just learn the common steps as Laurent says and forget about calculating on set :-)
Greets,
Dan
#5 Chris Keth
Posted 11 January 2006 - 03:09 PM
Michael,
Greets,
Dan
It's easiest to just remember the sequence of film speeds (or apply the compensation in your meter as such, as many meters can do that) rather than calculating anything on set.
#6 JA Tadena
JA Tadena
  • 30 posts
  • Philippines, Manila
Posted 12 January 2006 - 12:41 AM
Yes. I dont really think there is a need to calculate since you will never be on a set without a light meter. :)
