Steps to calibrate two cameras
#1 jasonjoseph
jasonjoseph
  • 5 posts
Posted 15 January 2006 - 01:43 AM
Was just wondering if anyone knew the best way to calibrate two cameras, a HVR-Z1 and a HVRA1P ? At the moment the colour output from these cameras is different and brightness is different too.
Also tips on setting up a monitor would be great.
Newbie~
#2 warner brown
warner brown
  • 64 posts
  • petaluma, CA
Posted 15 January 2006 - 05:51 AM
Newbie~
do all that crap in post production. final cut pro, don't worry about 'camera settings'
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 15 January 2006 - 06:35 AM
I don't agree. Camera settings are very important when recording to a compressed format. If it's not on the original you can't recover it!
Stephen
#4 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 15 January 2006 - 06:54 AM
For PAL monitors, switch the camera to bars, then adjust the brightness control on the monitor so that the Black bar on the right of screen matches the screen surround. Then you need to switch the monitor to Blue Only. The switch for this is usually bottom left. The display will change to black & white bars. Use the Chroma control to adjust the left most black bar so that it matches the surrounding screen, then use the Contrast control to make the extreme left bar White. Switch off the Blue Only, and your monitor should be properly lined up.
#5 jasonjoseph
jasonjoseph
  • 5 posts
Posted 15 January 2006 - 10:57 AM
Hi
i agree with Stephen, as an editor i wouldn't like to be given the extra task of fixing someone else's 'crap'
Newbie~
#6 Nick Mueller
Nick Mueller
  • 2 posts
Posted 15 January 2006 - 12:22 PM
Newbie~
Hello Jason,
Sounds like you need the manuals to these cameras. You want to learn how to ?white balance? the camera to match existing light and learn to operate the iris and shutter to control exposure. If you?re trying to match two cameras so that the over-all images are close to the same color balance, you would first white balance each camera on the same white card in the same light. If one camera appears bluer or warmer than the other, put some color correction gel on the light and rebalance camera. See if it gets you any closer. The HVR-Z1 may be easier to bring in line to the A1P, since it has gamma control and the A1P has a single CMOS. Color correction gels are used to change the color temperature, or Kelvin, at which a particular light is burning. These gels come in different strengths from 1/8th to full. Full daylight is bluer than household tungsten lamps or studio halogens. The camera?s white balance function performs a calibration that allows the camera properly reproduce colors under existing light conditions. You can manipulation this calibration by white balancing to subtle (and sometimes not so subtle) colors. Several video supply vendors carry what are called ?warming cards,? which are used to produce a warmer look on a tungsten setting (3200K) than would have been achieved with a white card. Visit Roger Macie?s site at http://www.macievideo.com/products.htm to see an example. Usual disclaimer, Roger doesn?t pay me or send gifts. I hope this helps Jason.
Regards,
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Hi
Newbie~
The whole point of grading is to make the image perfect, not make `crap' look acceptable!
The ability to fix it in post, is not an excuse for bad workmanship. Many things cannot be fixed!
Stephen
#8 G . Stephen Bruno
G . Stephen Bruno
Posted 15 January 2006 - 12:39 PM
:blink: ....
much like jason, if i had to deal with that headache in post, as a editor, i would be very annoyed. Do you have access to a waveform/vector? Dont they make CCU's for these types of cameras?
#9 warner brown
warner brown
  • 64 posts
  • petaluma, CA
Posted 17 January 2006 - 12:14 AM
Stephen
god knows what i was drinking that night.
I was just being sarcastic. :P
