Regular 16 versus super16 HD telecine
#1 Andrew Koch
Andrew Koch
  • 243 posts
  • Burbank, California
Posted 18 January 2006 - 05:47 PM
I am about to shoot a student film on regular 16mm. It will be telecined to D5 and matted to 1:85. The last project I shot was super 16 transferred to D5 with a 1:85 aspect ratio as well. The super 16 footage was 7205 250D and tranferred quite nicely. It was sharp as a tack and the resolution was phenonmenal. I only have acess to a regular 16mm camera for this next project which will be shot on 7229. Since this footage will have to be cropped more than the super16, am I going to have enough resolution from the film to make a sharp HD tranfer, or will it be slightly blurry. I would love to test it, but we do not have the budget for it. I am okay with the footage being a little grainy, my concern is will the reduced resolution be a problem.
Has anyone done an HD 1:85 transfer from regular 16mm?
Any advice would be greatly appreciated.
-Andrew
#2 Chance Shirley
Chance Shirley
  • 256 posts
Posted 18 January 2006 - 05:55 PM
Considering people have cropped/blown-up regular 16mm films to 35mm (CLERKS and EL MARIACHI come to mind), I would guess r16mm to HD shouldn't be a problem.
That's just a guess, though, as I haven't tried it personally.
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 18 January 2006 - 10:13 PM
-Andrew
I suggest giving the 7229 just a bit of overexposure (no more than a stop), which should help reduce graininess at the higher magnification needed for a Regular 16 transfer.
#4 Joshua Reis
Joshua Reis
  • 108 posts
Posted 18 January 2006 - 11:35 PM
When cropped to a 1.85 ratio, Super 16 (.488"x.263") offers 46% more film surface than standard 16mm (.404"x.218"). The tremendous loss in usable negative area will undoubtedly result in a softer transfer to D5. I am assuming you are speaking of D5 when it is in 4:2:2 1080p). I have transfered 7205, 7212, 7245 Super 16 to D5 and HDCAM from a Spirit 2k, as you have have done too, and yes the sharpness and resolution of the negative is more than adequate when you have a properly exposed negative (I realize this is subjective). However, having shot some standard 16mm tests (Fuji 250D and Kodak 7205) myself and transfered to HDCAM (1.78), I wasn't very pleased with the results. Again, it all depends on what your expectations are and the style of the look that you are going for, but I think the image will be unacceptably soft. If you are shooting with 7229, I would rate the stock at 320 ASA to get the extra density on the negative . If you were going to a 720p format I would feel okay, but a 1080p format is a bit of a stretch for standard 16mm. Ultimately, testing is the only real way to find out as there are other variables such as lenses, camera steadyness, and telecine that will affect the resolution throughout your production pipeline.
Edited by Joshua Reis, 18 January 2006 - 11:37 PM.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 19 January 2006 - 03:46 AM
If the lenses you use are very sharp, then you will get a good result. Using old cheep zoom lenses from ebay, will produce a sub standard result.
Stephen
