Konvas
#1 David Sweetman
David Sweetman
  • 757 posts
Posted 21 January 2006 - 12:49 AM
http://cgi.ebay.com/...1QQcmdZViewItem
The Konvas 2M
What do you guys think about these things? They seem to be the K-3s of 35mm. I assume the lenses might be drastically sub-par...though anamorphics seem cheaper and more available for the OCT-19 mount. (edit - i just looked again on ebay, didn't see any anamorphics, though there were a slew earlier)
...also I see you would have to get adaptors for the mag to use Kodak cores...any other strange things about this camera?
Edited by David Sweetman, 21 January 2006 - 12:58 AM.
#2 Trevor Greenfield
Trevor Greenfield
  • 162 posts
  • North Idaho
Posted 21 January 2006 - 12:57 AM
The Konvas 2M
What do you guys think about these things? They seem to be the K-3s of 35mm. I assume the lenses might be drastically sub-par...though anamorphics seem cheaper and more available for the funky OCT-19 mount.
There are quite a few threads on the Konvas here even its own sub forum which you may not have seen. In short, yes the lenses are pretty good and technically so are the cameras but they are loud (around 53db) and so they would take a miracle (or a lot of blimping and sound filtering) to shoot sound with. Much like the K3, however, many claim that these cameras can be used for B-roll very efficiently. Further, as can be obviously determined, this camera served on many European and Russian productions, some of which are very well known in foreign cinema circles.
#3 David Sweetman
David Sweetman
  • 757 posts
Posted 21 January 2006 - 02:33 AM
hey thanks...i should have searched first, but didn't think of it.
#4 Paul Bruening
Paul Bruening
    (deceased)
  • 2858 posts
  • Oxford, Mississippi
Posted 21 January 2006 - 05:08 AM
Hey David,
The pickle with the Lomo lenses is trying to work out all those alpha/numerical designations. Make sure you're getting something that really works and can be assembled as a set. Of course, onesies and twosies won't color match, but DI makes that a small issue.
It seems that there are a few basic categories: 1). Spherical primes with the KAS anamorphic adapter mounted in front. Apparently, these are the worst choice. 2). Square fronts. They're an older design than the round fronts. They're cheaper than the round fronts. But, they don't get a great deal of respect from DPs here on the forum. 3). Round fronts. These are the best from the Lomo line. They suffer from the least of the design troubles that come with anamorphic lenses. They are the most expensive as well. Even so, they are a dang-sight cheaper than most anamorphic lenses. Most DPs here respect their quality.
The further issue is mounting. Either the camera has to be remounted (other than the appropriate Russian camera) or the lenses have to be remounted, in some cases, rehoused. As well, they don't clear the mirrors of all cameras. Juggling all of these factors to end up with a good camera and Lomo anamorphics can be a bit mind-bending. You'll need to make friends with a reliable lens tech to hold your hand through the process. They'll do it if there's a job in it for them. They don't like using a whole lot of time just answering questions (my experience). Trying to get a straight answer out of the Russian sellers on Ebay is, generally, a waist of time. They say whatever makes the sale (again, my experience only).
If you do make a move on them, please, let us all know how they work out.
Paul
#5 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 21 January 2006 - 02:58 PM
The Konvas 2M
The Konvas 2M
---Actually the LOMOs are quite good, mechanically some are are beaten up. but visually are similar to older Cookes.
http://www.commiecam.com/
---LV
