Location of Bolex Serial Number
#1 failnaught
failnaught
  • 6 posts
Posted 22 January 2006 - 06:38 PM
I just purchased a Bolex H16 Reflex and I have been searching the location of its serial number. I was told that it was "inside its front cover." However, if that means that it is on the cover of the film compartment, then it is not there. Any ideas? I am such a newbie.
Failnaught
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 22 January 2006 - 07:09 PM
If you have one of the first generation Bolex H16 Reflex cameras, the ones without the flat base, I think the serial numbers used to be engraved on the bottom of the little round base sticking out of the bottom of the camera, where the 1/4"-20 screw mount is for the tripod.
One the newer flat base models, I may be wrong, but I thought I remembered them being on the bottom side of the base as well.
-Tim
#3 Boris Belay
Boris Belay
  • 210 posts
  • Brussels, Belgium
Posted 23 January 2006 - 09:23 PM
-Tim
Indeed, whether flat base or not, on later models it's under the camera, by the tripod mounting screw hole : look for an engraved 6-digit number between 100,xxx and 350,xxx.
On cameras before 100,00 or so (more like 120,000), the serial number is engraved inside the film chamber : either above the top spool spindle and/or inside the camera door (matching numbers, hopefully).
-B.
#4 failnaught
failnaught
  • 6 posts
Posted 24 January 2006 - 05:49 AM
-B.
There it is! Thank you guys for the help. You're the best!
BTW I bought a Bolex I was told was a REX 4, it turns out it is a REX 5!
- Failnaught
#5 Boris Belay
Boris Belay
  • 210 posts
  • Brussels, Belgium
Posted 24 January 2006 - 08:04 AM
- Failnaught
Do you mean that it has the mount for the 120m. magazine on top of the camera ? Or are you just going by the serial number ?
-B
#6 failnaught
failnaught
  • 6 posts
Posted 24 January 2006 - 10:24 AM
-B
Both! I noticed the magazine mount, which is why I was suspicious.
- Failnaught
#7 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 24 January 2006 - 11:13 AM
SCORE!!!
Congratulations, that's a much more versatile camera than the Rex 4.
-Tim
