Final Cut Issues
#1 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 25 January 2006 - 08:27 PM
So my most recent employers are trying to capture the dvcpro50 footage we shot this weekend, but in Final Cut pro 5, they can't find dvcpro50 24p listed in the choices for the capture presets. They've tried capturing as dvcpro hd, but the program aborts. I suggested going to apple support and looking for a dvcpro50 codec to download, but that seems to have been unhelpful. I can't be sure they're using the "proper" IEEE 1394 interface.
Any ideas???
JwR
#2 Michael Collier
Michael Collier
  • 1262 posts
Posted 25 January 2006 - 08:48 PM
Check the website for updates. I had a problem with HDV and premiere until I looked online and found the HDV patch. May not be that, but thats a good starting point
#3 Joshua Reis
Joshua Reis
  • 108 posts
Posted 25 January 2006 - 08:51 PM
Hi, what version of Final Cut and OS you running? Also, can you give me a little info on the hardware configuration and the deck model?
Regards,
Josh
#4 Gordon Highland
Gordon Highland
  • 261 posts
  • Kansas City
Posted 25 January 2006 - 09:09 PM
DV50 doesn't show up in the regular "Easy Setup" list. You need to check a little radio button or something off to the side in order to display the full list, and it's in there. There's nothing to download, support for it is built-in.
#5 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 25 January 2006 - 09:18 PM
Any ideas???
JwR
Like Gordon said, it's DV50 NTSC. If you shot 16x9 make sure you select "anamorphic". There won't be any 24p to select at capture since what you have is 60i coming from the tape. If you shot 24p Advanced, then that is in your sequence presets, but the tape is still 60i on the way in (capture) it's not 24p until you do the pulldown afterward. I think I've got that right.
#6 Gordon Highland
Gordon Highland
  • 261 posts
  • Kansas City
Posted 25 January 2006 - 09:29 PM
Oh, and one other thing, if you're capturing over firewire, and if you shot in 24pAdvanced, in the Capture Settings, you should select "Remove Advanced Pulldown" cuz it can do it in real time upon capture, saving you a step, and you'll get smaller file sizes (5.5 MB/s). And yes, technically the frame rate you'll want to select in that window is still 29.97. It's your sequence that should be 23.98 fps. The nice thing about anamorphic is that if you forget to check the box for it in your Capture Settings, the only thing it screws up is the aspect of the logging window, you can always fix the clips by putting a checkmark in the Anamorphic column in your bin afterwards for each intended 16:9 clip (of course you had to shoot it that way first).
#7 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 25 January 2006 - 09:36 PM
Gordon,
Thanks! I relayed the info by voice mail and will now wait w/ baited breath to see if this solves the problem. We quite specifically did not shoot advanced ... no chance of returning to film.
#8 Brant Collins
Brant Collins
  • 165 posts
  • Little Rock, Arkansas
Posted 25 January 2006 - 10:42 PM
video settings[attachment=951:attachment]
#9 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 27 January 2006 - 12:52 AM
I'm told it (dv50-ntsc) worked ... so thanks!
