35mm split reels on 16mm rewinds
#1 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 27 January 2006 - 01:08 AM
Will 35mm reels (Split and/ or regular reels) work on 16mm rewinders?
#2 Sam Wells
Sam Wells
  • 1751 posts
Posted 27 January 2006 - 11:01 AM
Yes
-Sam
I assume you mean proper rewinds, Moviola, Hollywood etc
Of course the 35mm splits won't fit on the 'short shafts' made for 16..
-Sam
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 27 January 2006 - 01:29 PM
Yes
-Sam
-Sam
If you have the shorter shafts designed for the narrower 16mm reels, you may not be able to close the hinged latch on the spindle, and may need to be sure the 35mm reel does not "walk" off the shaft. You may be able to buy longer spindles for 35mm reels.
#4 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 27 January 2006 - 06:47 PM
Great thanks, the diameter of the center hole though is the same then, only the shaft lengths are different, right?
