Making Flat Light more Interesting...
12 replies to this topic
#1 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 28 January 2006 - 02:42 PM
When shooting in an environment with an inherently low contrast (an overcast day for example) is there a way to make things look more interesting / colourful?
IE, using CircusChrome, a special filter or by exposing differently?
Or should one just have to live with what one can get in such environment?
Most of my filming is experimentation and home movies where I cannot always control the "scene" :)
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 28 January 2006 - 02:51 PM
Adding a light and negative fill will help, ts much easier with close ups!
Stephen
#3 Jaan Shenberger
Jaan Shenberger
  • 262 posts
  • San Francisco
Posted 28 January 2006 - 03:36 PM
the biggest advantage to shooting in overcast or very soft lit situations is that the texture and color of the subject matter will generally become more visually dominant over light & shadow. maybe using well color-coordinated wardrobe/production design/location might help. or integrate pattern and texture in a similar way too. or you could create your own kinda de facto light & shadow by juxtaposing dark objects against light to create the contrast missing in the lighting (ie. person in white outfit standing against a dark blue wall, etc). and you could overexpose a stop or so to saturate the colors (just use an nd grad for the sky, overcast skies often come out as white). and there's always shallow depth of field.
hope this helps,
jaan
#4 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 29 January 2006 - 02:27 PM
hope this helps,
jaan
Thanks for that!
#5 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 29 January 2006 - 08:19 PM
Costume and set design can also be used. For example, on an overcast day, flesh tones look very nice, but a bright red jacket or hat really "pops". Using fluorescent or brightly colored costumes can "brighten" up a flatly lit scene.
#6 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 30 January 2006 - 01:41 AM
A 220 shutter angle can give some extra saturation punch on an overcast day.
#7 David Mullen ASC
Posted 30 January 2006 - 02:13 AM
Why would the shutter have an effect on color saturation??? Especially when switching from 180 to 220 degrees (assuming you have a camera that can even do that.) All you get is more exposure. Are you talking about overexposing slightly and then printing down to gain saturation & contrast? Because you don't need to use a 220 degree shutter angle to do that.
#8 Josh Bass
Josh Bass
  • 552 posts
Posted 30 January 2006 - 02:21 AM
Just keep in mind that he mentioned that most of the time, the overcast days weren't planned. That could make the wardrobe/set dressing thing difficult unless he had a plan B for the overcast day.
#9 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 31 January 2006 - 02:59 AM
I don't know exactly why but I notice it quite a bit with low speed reversal. I live in a lot of overcast, often take out a canon 512XL with a fixed 220 shutter angle (have other cams with variable 180/220) and get better saturation with more exposure time. maybe the colors just bleed more? I also notice desaturation if I go to a 90 or 45 degree shutter.
#10 David Mullen ASC
Posted 31 January 2006 - 03:20 AM
Shutter angle just affects exposure time per frame, and assuming you compensate and expose correctly for the different shutter angle, the only affect will be on the amount of motion blur. There should be NO affect on color saturation. I mean, when you do still photography, do you expect a different color saturation at 1/30th, 1/60th, and 1/120th of a second, assuming you adjust the f-stop for the change in shutter speed?
#11 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 31 January 2006 - 09:47 PM
The exposure time may be what makes a difference in dreary overcast, comes out to about an extra 2/3rds maybe. Otherwise reversal rated at 25 or 40ASA daylight can get pretty muddy in those conditions. With negs, I did a shoot last summer with 7218, one camera with a 220 shutter, another was a beaulieu 4008 with guillotine (which translates to about a 130 shutter equivilant I think) But no difference in saturation.
#12 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 01 February 2006 - 02:54 PM
If the Kodachrome was getting muddy, it was probably underexposed.
Beamsplitter reflex viewers eat light.
---LV
#13 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 06 February 2006 - 09:13 PM
Yeah, thats probably the case, where I live 25ASA can be pushing it in winter overcast.. but using the 220 shutter always helped with K40. I've recently noticed the new 64T holds it's colors nicely when underexposed.
