Reference Monitor
#1 Andy O'Neil
Andy O'Neil
  • 154 posts
  • Asheville, NC (USA)
Posted 30 January 2006 - 08:46 PM
Shooting 720p24
Want 14" (not an on-board)
Durable/Non-cumbersome
16:9
Price sensitive ($1,000 - $3,000)
Any suggestions?
Thank you,
#2 Phil Rhodes
  • 12174 posts
Posted 31 January 2006 - 06:19 AM
Look at JVC's stuff. They make a wide variety of monitors which probably won't break that budget by too much (though they will certainly break it). Many of them aren't full-pitch HD, as in you're not quite seeing 1280 pixels per line, but they're "okayish" at that price range.
Phil
#3 Andy O'Neil
Andy O'Neil
  • 154 posts
Posted 31 January 2006 - 07:38 PM
Thanks, Phil, you rock.
Worked on a shoot several weeks ago with the Varicam (I wasn't shooting of course), but we used a ~$600.00 flat screen television from Best Buy as our reference monitor. Is that just crazy? It seemed to work fine, but I guess I don't really know what to look for in a monitor ... I mean, I want it to be "what-you-see-is-what-you-get" for the most part. Focus, Color balance, Exposure, etc. I guess it also depends on what the final output is going to be. I mean, what do I really really need?
Thank you,
#4 Phil Rhodes
  • 12174 posts
Posted 31 January 2006 - 08:59 PM
An LCD might show you framing and focus if you were lucky. They often do some really hideous up/down sampling which makes anything look soft, and obviously LCD colour and exposure information are completely unreliable.
I think you should look at something like a JVC DT-V100CG, which now I check is actually well under your budget. However, I'm not sure that it does 720p/24 (although I believe the Varicam output is 60i anyway). I know it does 1080/24Psf.
Phil
#5 Bruce Greene
Bruce Greene
  • 571 posts
Posted 31 January 2006 - 10:54 PM
Phil
Andy,
I'm using the Panasonic BT-LH1700W 17" LCD monitor with my Varicam. Price is a little under $3000. The monitor is very close to a calibrated (white balanced, not just color bars) CRT and is sharper than 20in CRT as well. Blacks are a little milky compared to a CRT though. It actually looks better in a room with some ambient light rather than in a black tent. I've even used it on the beach in bright sun and could still see an image (critical viewing did require a serious shade though)
Other pluses: It is light weight, runs on ac/dc, has HD-SDI and SD-SDI inputs, Analog HD and SD inputs, has a gamma corrector (approximate) for Film Rec mode on a Varicam, and a crude, but very useful waveform monitor.
I just used it today on a shoot with a Sony f-900 and it color matched a just calibrated Sony CRT very very well. And to my surprise, it did not look fuzzy when down-sampling the f-900 to 720 pixels and was even a little better than the 20in sony for judging focus, though not quite as sharp as 23in 1280 pixel LCD display.
Best of luck with your up-coming film.
-bruce
Oops, I meant "1080 pixel LCD" display.
#6 david garcia
david garcia
  • 5 posts
Posted 01 February 2006 - 09:50 AM
We're using that one too. It's really been nice. Street price is $2700.
#7 Sean Azze
Sean Azze
  • 145 posts
  • P.A.
Posted 03 February 2006 - 11:56 PM
So can you use just a standard def monitor when shooting on the hvx? Is a High def monitor required to just get an image, or more to get what the image will truly look like in post?
