Gyroscopic camera mount?
#1 Mike Kaminski
Mike Kaminski
  • 60 posts
  • toronto
Posted 01 February 2006 - 05:33 PM
A shot for an upcoming production requires the camera to rotate 180 degrees in-camera. Any suggestions on how to accomplish this? I know there are gyroscopic mounts out there but i am ignorant to any information about them.
#2 Dickson Sorensen
Dickson Sorensen
  • 131 posts
Posted 01 February 2006 - 08:28 PM
Majestic Light in New York supplied a 3 axis head for one of my productions. It was mounted on their Technocrane though I'm not sure if they rent it without the crane.
Chapman also has a three axis head.
Do you want to rotate the camera on the axis of the lens? Why do you want it gyro stablized? Is this a moving shot from a camera car or do you only need to rotate the camera from a fixed rig?
#3 Mike Kaminski
Mike Kaminski
  • 60 posts
  • toronto
Posted 01 February 2006 - 09:06 PM
i actually have no idea, im not dping it but i just thought i would ask around and see. I believe it is to be a fixed rig, with the camera rotating on the lens axis.
#4 David Erlichman
David Erlichman
  • 49 posts
  • Grip
  • Toronto, Ontario, Canada
Posted 01 February 2006 - 09:36 PM
Does the mount have to be gyro'd? The Mega mount (Mega III or IV) aren't stabilized but do offer a third axis. The Libra Head and Stab C are stabilized, but have a VERY limited roll. The Wescam (now Pictorvision) XR has both (and weights less then the Stab C).
If it's just a nodal point head (rotating on the centre of the lens) you want, then you could order a Weaver / Steadman with a third axis, or the Ronford F7 Mk whatever with a third axis.
If you just need to mount on your current setup, then Panavision has their famous "PanaTate" and there is fench make that I think Clairmont may have (I know of one rental house here in Toronto that has one) and for the life of me I can't remember the name right now. If I'm getting close let me know and I can call around. Cine sst here used to rep it (and made a motor conversion too).
Hope this helps
David Erlichman - Dolly Grip
P.S. I don't work for any of the above companies... I just have to use their stuff.
#5 BradHruboska
BradHruboska
  • 5 posts
Posted 01 February 2006 - 11:28 PM
There is also the Aero head, as well as the power pod 2000, and Weaver steadman, and scorpio, and the Z head on the techno......etc etc........
Hows the movie going Dave?
Brad Hruboska
Steadicam guy.
#6 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 02 February 2006 - 06:37 AM
will a "frazier" lens system make the trick?, it's a lens for primo mount that spin the image from it's optical center opdticaly, or use a 360° ring but if you are not flying or floating you don't need to be gyro stalilized from my point of view
#7 Mike Kaminski
Mike Kaminski
  • 60 posts
  • toronto
Posted 02 February 2006 - 01:45 PM
Thanks for all the replies guys, i think our most likely choice will be the Panatate.
