Detecting available load on a circuit
#1 Matt Irwin
Matt Irwin
  • 389 posts
Posted 09 February 2006 - 03:27 AM
Is there a way to use a meter (or something) to safely determine how much juice is available on a circuit? It would be good to know in case a situation comes up where not all plugs on a circuit can be checked or there is limited or no access to the breaker panel.
#2 Andrew Alward
Andrew Alward
  • 14 posts
  • Orlando, FL
Posted 09 February 2006 - 12:50 PM
You should beable to use a multimeter to determine the amps comming from the circuit. Then, you must figure how many amps your going to be pulling, as to not overload the circuit.
#3 Phil Rhodes
  • 12174 posts
Posted 09 February 2006 - 01:59 PM
Yes, you apply load until the breaker drops out or something catches fire. That's your maximum load!
Seriously, no, there isn't. You may be able to go and look at the breakers and find out what the safety is, but that's an upper limit not a lower guarantee, and other things (principally diversity) can complicated matters.
Phil
#4 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 09 February 2006 - 03:08 PM
One thing you can do is go to the clothes dryer outlet (if it's electric) and use a 220 breakout. Those circuits usually are rated for 60 amps and only have the dryer on them.
#5 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 09 February 2006 - 04:02 PM
Look into a device known as an amp probe. While it does not tell you the capacity of a given line, it can tell you what is currently being drawn on that line.
#6 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 09 February 2006 - 04:34 PM
Or a clamp meter - measures current via the induced magnetic flux in a wire, without physical intrusion of the circuit.
#7 timHealy
timHealy
  • 1262 posts
Posted 09 February 2006 - 05:30 PM
It may help to know the ampacity of the wire. Usually the gauge of wire is printed on the jacket, but not amperage. Wire size should be matched to the breaker ampacity.
http://www.susitnaen...ries/Wiring.htm
This "maximum ampacity for copper" as a general guide. wires do vary in ampacity based on wire size, type of wire, insulation, etc., etc. and other electrical codes in whatever town or country you may live in.
Best
Tim
#8 Matt Irwin
Matt Irwin
  • 389 posts
Posted 09 February 2006 - 11:11 PM
Thanks guys,
I'll definitely look into the "amp probe" and "clamp meter".
#9 Rolfe Klement
Rolfe Klement
  • 668 posts
  • London | LA
Posted 10 February 2006 - 03:35 AM
I assume you are asking about residential and commercial properties as opposed to generator loading. The best method that works for me is to isolate the load on the circut board, by seeing switching things on and off from the main board and each wall power point - then from a reading of the unit on the mains box (in UK 16A or 32A) and knowing the voltage I can figure out the load - assuming my test also made sure there are no other loads on the circut or I am running of a spur (very difficult to tell in UK) - but things tend to trip pretty quick if you over load in residential situations.
I had a gaffer and they were saying it is very difficult to use any tool to figure out loading on circuts where you cannot physically see all variables (Spurs, other loads, physically restrained trip switches etc) -
hope that helps
thanks
Rolfe
