Shooting Plasma set and Scroll bar
#1 oscar jimenez
oscar jimenez
  • 317 posts
  • PANAMA, REPUBLIC OF PANAMA
Posted 11 February 2006 - 03:29 PM
Any guess about scroll bar showing up on a plasma tv set screen, shooting at 30 fps @ 180 deg shutter ?
Thanks for feedback.
Oscar
#2 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 12 February 2006 - 04:04 AM
As far as I'm aware the scroll bar is not an issue with plasma screens (and LCDs too), only with CRTs.
#3 David Mullen ASC
  • 20068 posts
Posted 12 February 2006 - 11:22 AM
There's no bar, but Plasmas can pulse unlike LCD screens. Not sure how to "phase out" the pulsing though since I'm not sure what the refresh rate is or whether it is a 60Hz cycle (where using a 144 degree shutter at 24 fps may help. Or 30 fps with 180 degrees. Or if you need to be at 29.97fps. Assuming NTSC.)
#4 Filip Plesha
Filip Plesha
  • 1267 posts
  • Croatia
Posted 13 February 2006 - 06:42 AM
Speaking of plasma screens
I was just in a sony store today...
First I enter the store and see a big plasma HD TV/monitor and there is some kind of a static image of flowers on it. It looks like a big print is sticked on top of the screen.
It didn't appear to glow because it was day and the rest of the store was bright, so I actually thought it is a print on paper, then I come closer and see that it falls appart, and I see some vibration on the bright parts, so I figured out that it was the actual image on the screen.
I've never seen such a display with such contrast. I mean, that's like Star Trek. The blacks are like dark black plastic surfaces, and whites are glowing.
The image has a contrast of a print on paper. When not moving it actually looks as if you are looking at YCM print material, at least from some distance.
I can't believe display technology has advanced so much, consumer technology that is.
It reminds me of those sci-fi movies when they composite the images on the monitors, instead of shooting of monitors, the images look like a part of the scene photography because they are composited.
Well it seems we are there now, because on film, this kind of a monitor would look like the image is composited in.
Amazing.
