Digital Recorder Options?
#1 Mark Smith
Mark Smith
  • 62 posts
Posted 13 February 2006 - 07:05 PM
I know this is going to be a question that should be obvious...but digital audio is not my first field. I am looking for a device that will let me hook up two XLR microphones and record into my powerbook. The catch is that I want the sound from each microphone recorded on its own seperate track. Is that possible with the mbox? If not, what other products [in the same price range do this]...and also, has anyone ever used the Tascam US-122 - it looks to be about the same thing as the Mbox [with different software]...but if anyone knows if this supports the kind of multitrack recording I need, i.d love to save the money.
Mark.
#2 Patrick Casey
Patrick Casey
  • 24 posts
Posted 13 February 2006 - 08:17 PM
I don't know how rugged thhe solution has to be, but my recommendation would be to just a a FW soundcard like the M-Audio 410, and then you would have a nice soundcard to do audio work with as well. I'm sure that there are cheaper variants.
My sound dept. basically does this but they have a Moto Traveller since they need more inputs.
Best of luck!
#3 Peter Duggan
Peter Duggan
  • 46 posts
  • Sound Department
Posted 14 February 2006 - 01:09 AM
IF your budget allows for it, check out the Digidesign 002 digital rackmount mixer. It's expensive, but it's one hell of a mixer and will record very well onto your powerbook and comes with great software.
http://www.digidesig...ts/digi002rack/
#4 Mark Smith
Mark Smith
  • 62 posts
Posted 14 February 2006 - 07:48 AM
The budget doesn.t really allow, but the main question here is not really being addressed...which is does the mbox...or tascam us-122 record the seperate mic imports on different tracks or not...the digi002 would be nice because I.d get 4 imports instead of two, but right now I can cut it with two...maybe in the future i.ll pick up the digi...but right now the budget won.t allow it.
Mark.
#5 Werner Van Peppen
Werner Van Peppen
  • 22 posts
  • London, UK
Posted 14 February 2006 - 09:00 AM
Mark.
Yeah it would be stereo, which would allow you to record each input on a separate channel. You could also try a firewire powered unit from motu. motu traveller. That would give you the means to do a multichannel mix at home and you'd have more inputs. Get a cheap behringer mixer and you could go upto 6 channels.
I know budget is your issue but it's better to spend a little more money upfront rather than buying something you probably can't use or doesn;t suit your purposes down the line.
#6 Phil Rhodes
  • 12171 posts
Posted 14 February 2006 - 11:08 AM
There are some absolutely great firewire audio devices in the $500 range. That and a laptop and you're good. I don't think it can be done well for much less than that.
Phil
