Can I push 1/2 a stop?
#1 Matt Sander
Matt Sander
Posted 15 February 2006 - 09:49 PM
Can most labs push super16 negatives by 1/2 a stop?
#2 Jarin Blaschke
Jarin Blaschke
  • 253 posts
Posted 15 February 2006 - 11:59 PM
It depends on the lab, but I know most do - at least in 35mm.
#3 David Mullen ASC
Posted 16 February 2006 - 12:04 AM
Hardly seems worth it, since that's only like a 3 to 4 point correction on the printer lights, within a margin of error for exposing, and probably would not give you EXACTLY a half-stop more density.
If you're pushing in order to shoot in lower light, it seems like you could find another half-stop somewhere.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 16 February 2006 - 03:47 AM
Many labs will tell you they can push 1/2 stop. In reality it may get processed as normal or push 1 stop.
Stephen
#5 Sam Wells
Sam Wells
  • 1751 posts
Posted 16 February 2006 - 10:12 AM
Since I often rate a one stop push 2/3 stop faster, a half stop push would be ~ 1/3 stop gain (not doin' the logs here sorry :)
IOW yes sort of exactly !
-Sam
#6 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 16 February 2006 - 09:31 PM
Why would you want to?
#7 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 17 February 2006 - 01:35 PM
Not really a routine service offering. Changing to a different "push" or "pull" processing condition usually means clearing the processing machine of film by threading in leader, changing the machine speed, then running a control strip to verify the sensitometry of the process. This all takes time away from production, so there is an extra "setup" charge, and a limited number of conditions offered.
With minus half a stop exposure, the latitude of the Kodak VISION2 color negative films will usually produce a very usable image with a normal process. Push-1 if you want to increase the contrast a bit, along with a bit more graininess. Remember, a push process does not really increase true speed as much as you hope, it just increases the overall density and contrast of the negative.
