Metering for super 8 cameras.
#1 Nathan D. Lee
Nathan D. Lee
  • 69 posts
  • 2nd Assistant Camera
  • Salt Lake City
Posted 16 February 2006 - 08:02 PM
Up until now I have been relying on my cameras built in light meter for shooting super 8. I am not so much a fan of that for obvious reasons. So I bought an older Minolta III light meter. The meter can do shutter speeds but not angles and can be set to a 1/50 of a second for 24fps with a 180 shutter. The rest is ASA compensations and the like, which is fine.
I know you can find info on the shutter angle of many super 8 cameras but not all. Is it safe to assume that most are around 180 degrees? (I know some XL's go to 220 and some are at 160) Am I pretty safe sticking it at 180 unless I know otherwise?
Also a 180 degree shutter at 18 fps is around a 1/35, or 1/30 minus 1/3 a stop. Is this accurate? That seems like and awful slow shutter to me. but is that the world of super 8?
#2 Nathan D. Lee
Nathan D. Lee
  • 69 posts
  • Salt Lake City
Posted 16 February 2006 - 08:58 PM
Well, just found the website: www.kolumbus.fi/puistot/
it has a pretty comprehensive list of cameras and shutter angles. It looks like more camera have 220 shutters than i thought.
The difference in metering for 220 over 180 is +3/10th of a stop. So for all intents and purposes, +1/3rd a stop over 180 degrees att he same settings?
Correct me if im wrong.
#3 Sean McHenry
Sean McHenry
  • 175 posts
  • Hilliard, Ohio
Posted 20 February 2006 - 12:40 PM
I'm new to all this but shouldn't the shutter speed be double the frame rate? 24f=48s (in video I hear to choose 50 for shutter), etc.
Still learning. Did you find the angle for the Canon 814 Auto Zoom anyplace?
I have heard 2 sides to using a meter now. Some say that's the only way to go as the old meters in our cameras might be off after 25+ years, and I think that might be true. The other side says the internal meter is the best because it is behind the prisms, etc so it is the only accurate way to measuer what's hitting the film.
Sean
#4 Matt Sandstrom
Matt Sandstrom
  • 464 posts
  • Stockholm, Sweden
Posted 20 February 2006 - 03:35 PM
yes, the built in meter takes the prism into account, but why this would mean that it's better is beyond me. just figure out how much your prism steals and you're set. half a stop is a fair guess. or 1/3 if you're light meter doesn't have half stops. a grey card will tell you for sure.
/matt
sure, if the angle is 180 degrees which is exactly what they're discussing.
/matt
#5 Andy_Alderslade
Andy_Alderslade
  • 1055 posts
  • London, UK
Posted 20 February 2006 - 07:47 PM
according to american cinematographer manual Ninth edition
180 Degrees
24fps = 1/48 18fps = 1/36
220 Degrees
24fps = 1/40 18fps = 1/29
95 Degrees (like my Beaulieu 4008)
24fps = 1/90 18fps = 1/68
If you said which camera you used maybe someone would know, but I guess its worth doing your own tests with some reversal film to see what you like.
#6 steve hyde
steve hyde
  • 446 posts
  • Seattle
Posted 20 February 2006 - 09:55 PM
This thread has a good table in it that references shutter speeds for different MP cameras.
http://www.cinematog...topic=10509&hl=
Steve
#7 Steve Wallace
Steve Wallace
  • 163 posts
  • Burbank, CA
Posted 20 February 2006 - 11:40 PM
Sounds about right, I have always compensated 2/3 for the reflex viewer / prism.
