Skateboard wheels for Dolly
7 replies to this topic
#1 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 17 February 2006 - 05:20 PM
I have a Modern Skateboard dolly. Four Wheels per Corner. The problem is the wheel are getting a flat side while waiting, causing a bumping during the move. Does anyone have any recommendations for a brand of skateboard wheel. The diameter is 68mm. I'm thinking of going with Powel Bombers 68mm with a 85 hardness.
#2 kata
kata
  • 23 posts
Posted 17 February 2006 - 10:38 PM
try getting some that are rated 100a. that's the hardest you'll find. They used to make some skateboard wheels out of ceramic in the 60s I believe, but they stopped manufacturing them because they would shatter into dust on hard turns....
#3 dd3stp233
dd3stp233
  • 102 posts
Posted 18 February 2006 - 05:37 AM
99a hardness wheels (polyeurathane) are easy to find these days. They also make 100a polyeurathane wheels too but are a little harder to find. The higher the number the harder the wheel. I've seen some 78a wheels around, I think those are the softest now being made. Swiss bearings are best.
#4 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 18 February 2006 - 06:33 PM
Bob,
My experience has always been that the dolly grip takes care of the flat spots by rolling the dolly back and forth in between takes. Is this not working? I don't think you want wheels that are too hard, because then you're more likely to feel any little bumps or imperfections in the track that much more. I guess it's a matter of finding a happy medium.
#5 Josh Bass
Josh Bass
  • 552 posts
Posted 18 February 2006 - 07:27 PM
I have a buddy who's attempting to build his own, if you will. . .
Where does one find these wheels?
#6 Rik Andino
Rik Andino
  • 783 posts
  • Electrician
  • New York City
Posted 18 February 2006 - 08:15 PM
Well if you're looking for skateboard wheels...how about a skateboard shop...?
http://www.skateboard.com
This place has a good selection.
Also check out Long Valley Equipment's site
http://www.longvalle...p.com/dolly.php
Good Luck
#7 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 18 February 2006 - 09:49 PM
Being a Longboard- Slamon-Skateboarder I'd recommend the Kryptonics Classic K, they come in different hardness 78A,80A or 83A. The Kryptonics Route Series are a good choice too...
100A hardness might be a bit bumpy and noisy too...
#8 Ray Perry
Ray Perry
  • 5 posts
  • Rhode Island
Posted 09 June 2006 - 11:28 PM
We are a large inline and skateboard wheel maker the was told about the flat spotting problem. We have used our patented technology to produce a camera dolly wheel the will not flat spot (not even in cold and hot environments) The wheels are generally soft around a 62 Shore A and give a super smooth roll with no noise and very low rolling resistance so they roll very easy compared to other wheels. When needed we can add an outer coating to make the wheel harder. But we are finding that softer wheels are taking the lead in this application. These wheels are produced with a super high rebound material that solves the dolly wheel problems. If the wheels are slightly staggered the results are unbelievable.
DollyWheelMan (Ray Perry)
