Converting the Konvas 1m to Techniscope
#1 Stephen Whitehead
Stephen Whitehead
  • 124 posts
  • Toronto, Canada
Posted 11 March 2006 - 08:59 PM
What is the process of converting a 1m to techniscope? I know that you have to change the gate, but what is involved in re-adjusting the motor so only 2-perfs are pulled down instead of 4? also will this decrease the noise slightly and increase the frame stability due to the decreased motion?
Cheers,
Steve
#2 Jon-Hebert Barto
Jon-Hebert Barto
  • 349 posts
Posted 11 March 2006 - 10:11 PM
Unfortunatly, converting a Konvas of any make or model is expensive. About $5,000 US dollars. No , I am not kidding. There are places you can go for this, like Aranda (?) in Australia. I believe they are a member of this site so keep watching this thread to see if they post.
In the meantime I'll tell you what I know...
It does NOT greatly diminish the noise level of the Konvas.
As I said, it is expensive.
You basically have to fabricate new parts and refab existing ones.
The movement is completely rebuilt !!!
The 1m is not the camera I would do this to....maybe a 2M or 7M. They at least have crystal control and are a little bit newer. Remember that the electronics of russian cameras are limited and will one day fail for good!!! Converting a 1M cost too much for this type of camera, IMHO. I like Konvas' and stick up for them plenty, but I just want to give you my .02 . The cost ratio is just too high for this particular camera....
Sell your 1M and save some more dough for a Eclair Cameflex. They are also known as CM3 and something else I forgot... ;) These cameras take the techniscope transition much better and have a good track record with this upgrade. THX-1138 and American graffiti were filmed with this package...and lots of talent!
Again, Konvas' are great, sturdy little buggers but it just doesn't make much sense to me. It's like putting a Yenko Camero engine inside of a Rambler. Like I said, keep an eye on this thread and Bruce may give you better info....
#3 Bruce McNaughton
Bruce McNaughton
  • 114 posts
  • Melbourne Australia
Posted 13 March 2006 - 02:37 AM
Hi
Yes he just about covered it. The Konvas is not the best choice for 2 perf conversion, any model. However the later the model, the better is the ratio between cost of camera/cost of conversion. All Konvas models cost just under $USD5,000 to convert compared with an Arri 2C at $3,500. I know which camera I would prefer... Spend the saved $1,500 and buy an Arri...
The design of the Konvas does necessitate a thorough re-build, complete claw, crank, main shaft, counterweight, magazine drive, gate of course. We provide a new 2.35:1/1.78:1 ground glass for all cameras but the Konvas alone has a poor viewfinder design which darkens severely, starting at the edges, as you stop down. I guess this and other design inadequacies (you can't check for scratches easily, you can't observe if the film is running freely, difficult-to-load magazines, very ordinary motor mounting system...) is why they are cheap to buy.
But if you are going into a 2 perf production and you have a Konvas, you can still use it in 4 perf as an emergency backup to 2 perf cameras and extract the 2 perf images from it. This way it gets some use.
Regards
Bruce
