XL1s - sporadic video/audio recording problem
#1 Johann Diel
Johann Diel
  • 2 posts
Posted 14 March 2006 - 07:06 PM
Wondering if anyone here can help diagnose this sporadic issue,
two event recordings have been ruined because of it, at
one event...the 1st tape I shot was perfect the 2nd was
bad. The other event, the recording was bad all the
way through..... but a week before I shot two other
events and there were no problems. A vertical strip (1/4 inch wide) of pixellation appears on the right hand side of the video.
Figured its better to show folks, so the link below sends you to a clip I made of one of the bad recordings. it is a quicktime file.
http://www.home.eart...deoproblem.html
Any help would be appreciated.
Johann
#2 David Sweetman
David Sweetman
  • 757 posts
Posted 14 March 2006 - 07:22 PM
Try cleaning the heads. If you haven't done that already, that's definitely where I'd start. And if you've been using the camera for a while and haven't cleaned them, that's probably the issue. Also, you might want to try playing the tapes in another deck to see if you get the same problem.
#3 Johann Diel
Johann Diel
  • 2 posts
Posted 14 March 2006 - 07:51 PM
Thanks David,
I have not tried cleaning the heads, that will be something I'll do, but I have played the tapes on anothe player and another camera and they still have the same vertical pixellated line. what is strange is that I have recorded tapes before and after and in between these two problem tapes and have not had the problem show up.
Thanks, I'll go ahead and try the head cleaner.
