Keying out windows?
#1 Alexis Hanawalt
Alexis Hanawalt
  • 18 posts
  • Santa Monica, CA
Posted 23 March 2006 - 12:57 PM
I'm shooting a low budget spec spot in HDV and I need to composite an artificial background outside the windows of an office location.
I don't really have lights to spare besides the practical office lighting. I intend to tape up cardboard painted chroma key green to the windows and just keep the actors a good distance away - but I'm curious if it might be good to leave about 1 inch all the way around each window with light still coming through to maintain the illusion of real daylight spilling in. I'm concerned that this might allow for a lot of spill. I'm using Keylight with After Effects, so I know I'll have a lot of control, but I just want to be sure I do this in the best possible way.
Any suggestions?
#2 Austin Schmidt
Austin Schmidt
  • 82 posts
  • New York, Los Angeles
Posted 23 March 2006 - 01:14 PM
The problem with covering the windows rather then placing the green outside is that you will prevent natural light coming through them and so you will need to create that same light inside plus light the green as well. In otherwords, a lot of lighting units is needed which it doesn't seem like you have. A post fx guy and I solved this problem by covering the windows with tracing paper and letting them go overexposed with a consistent white. He then used this "pure white" as a frame to cut out the window as a hard matte. If you need the shot to be moving it can be done easily if trackers are taped along the outside of the windows. Best thing to do is to just shoot a cheap test (even with a minidv camera) to see how the hard matting will look (If it passes on the minidv test then I'm sure it will be fine on HDV). Key is to blend it together so it doesn't look like you cut and paste (but thats why the post guys get paid the big bucks)
#3 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 24 March 2006 - 09:46 AM
If the camera isn't moving, all you need to do is to expose once for the action in the room and then record a plate exposed for the exterior. Then you combine the two in post via a Difference Matte - no need for green screen.
On my latest music video, all the day interiors in the hotel (except the one in dusk) were done this way. First a normal pass in telecine with the beauty grade, then a fully cranked down one for the exterior - a so called two pass in telecine. Film has the upper hand here though - it can hold information in the highlights that video can't. But you can always expose for the sky with video as a plate.
Have a look at it here:
http://www.adamfrisc...indexmovie.html
#4 Alexis Hanawalt
Alexis Hanawalt
  • 18 posts
  • Santa Monica, CA
Posted 25 March 2006 - 12:26 PM
I shoot today - I think I'll try both with a greenscreen taped to the window and the Difference Matte route... Thanks for the suggestions!
#5 mark preston
mark preston
  • 2 posts
Posted 25 June 2006 - 04:07 PM
I was wondering if the bus shots within that music video were also done the same way as I am planning on using a stationary train carriage and keying out all the windows? The bus interior shots looked liked they might have been done the same way.....but somehow I doubt it.
#6 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 25 June 2006 - 04:44 PM
No, the bus shots were pretty much as is. I did put some windows in telecine to get more info out of the back window, but that's about it.
#7 seth christian
seth christian
  • 189 posts
  • Nashville, TN. USA
Posted 05 October 2006 - 02:51 PM
16mm? yes?
even though the imagery didn't contain a story or point to me...
I LOVED some of the imagery...the bus shots were magnificent,
all the warm colors were a spectacular pleasure!
well done.
