DSR450 'Start record-button on' speed.
#1 Frankieplus
Frankieplus
  • 5 posts
Posted 30 March 2006 - 07:48 AM
Does anyone know if this camera is capable of an almost instant start record/button on speed?
The camera seems to start recording around 3-4 seconds after I press the 'start' button on the lens (as do most cameras) I'd like to change this if possible.
I saw an old DSR250p today and the botton on speed was instant! As soon as you press the button it's -bang- instant record at that split second. I can't help thinking that if the DSR250 can do it then why can't the DSR450?
Could there be something in the menu for this?
Secondly, I was thinking of setting my VTR standby/off timer to 5mins rather than the default 1 min. Am worried that this is going to wear my heads away a lot quicker. Should I be concerned?
-Frankie
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 March 2006 - 07:54 AM
-Frankie
Are the heard in save mode? flick the switch to standby and you should get a virtually instant start.
Your heads will wear faster, but I don't think that will be a big issue.
Stephen
#3 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
  • Portland, OR, USA www.peterdv.com Blog: http://herefortheweather.wordpress.com/
Posted 30 March 2006 - 02:50 PM
Hi Frankie: To the best of my knowledge, the only feature which affects the DSR-450WSL's record start-up time is the "STBY OFF TIMER" setting in the Maintenance menu. Setting it to a value higher than the 1 minute default, such as 3 or 5 minutes, will result in the cam going into standby mode less often (at longer intervals). Depending on how often you put the cam into record mode, this may result in a faster record start-up time.
My previous cam was a DSR-250, and its record start-up time was about a second -- same as the DSR-450WSL if it hasn't gone into standby mode.
There are some cams which feature solid-state memory buffers to enable instant record start-up times, or to continuously record the several seconds previous to when the record button is pressed (so they're never missed), but the DSR-450WSL and DSR-250 don't have this feature.
