Arri S motors used for high speed photography
#1 kev5000
kev5000
Posted 01 April 2006 - 11:00 AM
I'm planning a shoot using an Arri S were we film items being broken in slow motion. I'm trying to find a motor that can run at least 64fps and over but have had no luck in finding one. Does such a motor exist for the Arri S and where. The Arri variable speed motor only runs up to 50 fps.
#2 Tim Carroll
Tim Carroll
  • 2170 posts
  • Chicago, Illinois
Posted 01 April 2006 - 12:31 PM
If you are going to be using the Arri 16S at higher than 50fps, you need to find one of the few high speed Arri 16S cameras. I run across one every now and then. They go up to 80fps if memory serves.
Running 12 volts through the standard Arri variable speed motor can sometimes make them run faster than 50fps (it can also burn them out), but you risk damaging the camera unless you have one that goes to 80fps.
-Tim Carroll
#3 Sean Charlesworth
Sean Charlesworth
  • 15 posts
  • San Francisco Bay Area
Posted 17 April 2006 - 01:01 PM
TCS sells a 12V motor that will go to 50, but they do mention you can use 14-16V for 60+. They just recommend not doing it very much. The only other trick is to have an S where the tach goes higher than 50, because like the original motor, the TCS isn't marked with FPS.
TCS motor
#4 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 17 April 2006 - 05:11 PM
I remember seeing an Arri S at Du-All that they modified to go 90fps.. or was it 150fps... I can't remember...
Give them a call: 212-643-1042
