400' Mag question
#1 Mark Smith
Mark Smith
  • 62 posts
Posted 13 April 2006 - 11:29 AM
I should know this, but do not...I tried to post it yesterday but it was somehow deleted. If I am using a camera that takes 400' cores, on the take up side, what do i attach the film to? Another core? What size diameter? Etc.
Mark.
#2 Chance Shirley
Chance Shirley
  • 256 posts
Posted 13 April 2006 - 11:43 AM
Arri SR cameras have a special permament core on the takeup side that is removed before bagging and canning the exposed film. Other cameras (Aaton LTRs, for example) use the same type of plastic core that the factory-fresh stock comes rolled on -- I believe the diameter is 2".
If you ask, labs will often send you spare cores, bags, and cans for the price of shipping.
#3 timHealy
timHealy
  • 1262 posts
Posted 13 April 2006 - 01:35 PM
Just for your info it is called a collapsible core and they are not permanent. They can be accidently sent off to the lab with your film.
something from the archives:
http://www.cinematog...x.php?t119.html
Best
Tim
#4 Mike Kaminski
Mike Kaminski
  • 60 posts
  • toronto
Posted 13 April 2006 - 01:53 PM
Mark.
Most newer cameras use collapsible cores, which the film feeds into and is manually clamped secure. Otherwise you just use standard 16mm cores, fold the film 1/8 of an inch or so and hook it into the slot on the core and then wind it around a few times to make sure its nice and tight. If you know what camera you will be using you may be able to locate the manual online and they usually have instructions for mag loading as well.
