Konvas Lubrication
#1 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 23 April 2006 - 02:23 PM
I bought a Konvas on Ebay. I have tested the camera and everything seems to work fine. Does anybody know what points inside need oil or grease? as I don't want to seize the camera on the first shoot!
Many thanks
Stephen
#2 Ian Dudley
Ian Dudley
  • 44 posts
  • Brooklyn, NY
Posted 23 April 2006 - 03:01 PM
Many thanks
Stephen
Check commiecam.com for a complete oiling diagram. I think it's in the resources page.
regards,
Ian
#3 dancordle
dancordle
  • 34 posts
Posted 24 April 2006 - 08:39 PM
Many thanks
Stephen
Hi Stephen,
If you go to http://www.smartgrou...m/groups/Konvas and link to the pictures area, You'll find some excellent photos of the Konvas lubrication points on page 2 of the scrapbook.
Congrats on getting a Konvas. I'm shooting my first real project with my "new" 2M next month.
Best,
Dan Cordle
#4 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 25 April 2006 - 03:37 PM
=I bought a Konvas on Ebay. I have tested the camera and everything seems to work fine. Does anybody =know what points inside need oil or grease? as I don't want to seize the camera on the first shoot!
After long time storage of Konvas need make full service with detailed inspection and adjusting of mechanical and optical parts.
Because, the old oil can dry up and need wash.
Will need inspect of every magazine too ,because, the mechanism of magazines give load on base mechanism of body.
Yes,of course, you can make easy oiling of mechanism and this can help on short time.
The base points of re - lube of lubricating liquid ( 2-3 drops )- central hole on axis of mirror disk,
and parts of frame of transport pin. You can do this procedure without take away front part of body.
Will need set oil on post of frame of transport pin too, but, you can do this with take away front part of body.
If you take away front part of body, you will need to check of flange focal distance of body.
The service of ball bearing of magazines possible with disassembling parts of magazine only.
The service of base reducer of motor possible with disassembling of motor only too.
