Bolex H16 Rex, can I modify shutter and go out of phase or 90 degrees?
#1 vale Spada
vale Spada
  • 2 posts
Posted 25 April 2006 - 03:13 AM
Hi, I was wonderin if there's a place where I can have this job done. And if this particular Bolex model can handle a shutter change to 90 degrees or go out of phase. thanks...
p.s. I also need to find batteries for this camera, where can I go? thanks again
vale
#2 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 25 April 2006 - 06:53 PM
Which model RX ?
You need batteries ? for the EL, EBM, the wind-ups with a motor attached ? I happen to have a 1,2Ah bolex batt, but if I didn't i'd be heading to an electronics surplus store to pick up any 12v rechargeable batt (like a motorcycle style, or two alarm 6v batts in series etc... )
I'm certain that the RX4, 5 and SBM have an adjustable shutter that can go from 130 deg down to zero - look for a little knob just ahead of the rewind shafts that you can pull out and move up and down (down = smaller angle) - I'm not sure about the earlier RX's or the EBM but I know the EL is fixed at 170 deg
Out of phase: as in you want the shutter open when the film is moving for vertical streak type effects ?
... again RX4 and RX5 yep you can for certain - you just need to unscrew the whole front shutter mechanism spin the shutter and screw it back on - statistically speaking you will put it back on out of phase :lol:
pretty sure its the same for the earlier types but again I dont know about the EBM - the EL yes probably but be careful you dont mess up your metering and wotnot
It can be a laborious process getting it back in phase I tell ya <_<
#3 vale Spada
vale Spada
  • 2 posts
Posted 26 April 2006 - 05:56 PM
Hi and thanks for your reply,
The camera says H16 Reflex, so i gues is the rx 1, I mean the first model i think.
It was a gift. But no batteries attached to it.
#4 Nick Mulder
Nick Mulder
  • 1023 posts
Posted 26 April 2006 - 07:08 PM
have you managed to find the battery compartment yet ???
The early H16's (and the current model SBM and RX5) are all spring wound cameras - they dont need batteries unless you have attached a motor to the side, I'm not sure if the RX1 had a motor made for it -
www.evergreen.edu/media/pdf/Bolex_Manual.pdf
have a read... it might be for a later model but the bolex designs concepts are very similar throughout the range ...
as for your question re. the shutter angle - check if it has a variable shutter like I said - if it doesn't then you probably wont be able to get one going for less than the cost of a body with one in the first place...
find your serial number near the base and reference with :
http://www.city-net....tory/index.html
helpful also:
http://www.tobincine...com/page94.html
Edited by Nick Mulder, 26 April 2006 - 07:15 PM.
