Pelang 8mm on K-3??
9 replies to this topic
#1 Landis Tanaka
Landis Tanaka
  • 54 posts
Posted 09 May 2006 - 01:38 AM
Yo d00ds,
I was thinking of buying a Pelang 8mm M42 lens for my K-3. but I heard there was some sort of flare problem or something? could someone explain that please? also Im gonna be shooting snow with it so does anyone know how I could get some rear glass ND filters for it or something?
thanks d00ds.
#2 Sir Alvin Ekarma
Sir Alvin Ekarma
  • 211 posts
Posted 09 May 2006 - 09:34 AM
Yo d00ds,
thanks d00ds.
Go here for more info on the flaring. It's in regards to 35mm SLRs but it still applies. http://www.pauck.de/...ng_fisheye.html
Re: ND filters. You'd probably have to make a DIY matteboxe and slip something in but I've never tried it.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 May 2006 - 09:57 AM
I guess you would have to use glass ND filters on the back instead of the blank one required to achieve infinity focus.
Stephen
#4 Mark Dunn
Mark Dunn
  • 2665 posts
Posted 09 May 2006 - 10:22 AM
That internal flare only seems to affect the edge of the field of view on 35mm, which you're not using on 16mm.
I imagine you could fix a bit of gelatin ND inside that screw-on UV filter with Blu-Tack or something.
#5 Landis Tanaka
Landis Tanaka
  • 54 posts
Posted 10 May 2006 - 02:26 PM
Does anyone know where I can BUY some rear glass ND filters for it? I've heard about DIY ones but I have no idea how to do that either.
#6 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 10 May 2006 - 02:48 PM
Peleng 8 mm lens have 4 rear filters:
- compensative, on lens
- UF
- Orange O-2.8x
- Green YG-1.8x
This is spceial rear filters for Peleng and other filters i don't know.
You can take any neutral density or compensative Gelatin filters, cut circle and set between rear glass of lens and rear compensaive filter.
But, Peleng lens have field distortion and you know about this.
If you need wide angle lens without big distorction, posisble useK-3 with bayonet and 12. 5 mm prime lens or
modifed 16 OPF-12-1 zoom lens 10-100 mm or with 0.75 front wide adapter 7.5-75 mm
#7 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 11 May 2006 - 09:20 AM
- UF
- Orange O-2.8x
- Green YG-1.8x
I've been looking for an 85 filter for my Peleng and my 16mm lens as well; both with that back end screw in filter. Anyone run across something like this?
#8 Chris Keth
Posted 11 May 2006 - 10:52 AM
- UF
- Orange O-2.8x
- Green YG-1.8x
Just be aware that any gelatin filters you put behind the lens will change the backfocus distance by (if I remember right) half the thickness of the filter. Eye focusing will work fine but the distance marks on the barrel would be out of alignment.
#9 Galen Carter-Jeffrey
  • 129 posts
Posted 11 May 2006 - 12:23 PM
Where can I buy a Pelang lens for a good price?
#10 Chris Keth
Posted 11 May 2006 - 12:40 PM
They come up new on ebay quite often, or kievcamera sells them. Just goggle them and you'll find the exat url.
