Tape Colors
#1 Gino Terribilini
Gino Terribilini
  • 75 posts
  • Long Beach, CA
Posted 09 May 2006 - 04:25 AM
I've been on set a few times where specific colors of tape are needed, but I still don't know exactly what each color means.
This is what I know:
  • Black- Exposed film
  • White- Unexposed film
This is what I want to know:
  • Blue on the camera/ mags/ can
  • Red on the camera/ mags
  • Pink tape
  • Yellow tape
  • Green tape
  • Anything else I should know about colored tape...
#2 Mike Panczenko
Mike Panczenko
  • 324 posts
  • 2nd Assistant Camera
  • Philadelphia, USA
Posted 09 May 2006 - 05:20 AM
  • Pink tape
  • Yellow tape
  • Green tape
White is for recans, unexposed film that you have opened but not shot and actually, as the name suggests, recanned. It also can be for short ends, you just write the length on the tape.
Blue is for the daylight stock, if you have one. Red is for the high speed stock. Pink, yellow, and green, are assigned to the other stocks at the ACs choice. In fact, there are no true hard rules other than black is exposed. The white as recan/short end and the red and blue colors are used most of the time when applicable, but if there is no daylight stock or no high speed stock, then these are often assigned anyways. The white being unexposed is also only if you are shooting one stock for the entire show. Otherwise, when you recan or short end it, you normally tape it up with the color you have assigned the stock (ie blue, white, pink, red) so that you can tell easily and without confusion which stock it is a short end or recan of.
#3 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 09 May 2006 - 10:42 AM
As you know, Kodak camera films are packaged with color-coded tapes as a secondary check on the identification provided by the can label and the printing on the tape:
5218 Copper
5248, 5212 Green
5245, 5279 Gold
5284, 5229 Light Green
5293, 5274 Mauve
5246, 5205 Blue
5277 Gray
5289 Orange
5285 White
5217 Maroon
5201 Teal
http://www.kodak.com...1.4.15.18&lc=en
#4 Matt Irwin
Matt Irwin
  • 389 posts
Posted 09 May 2006 - 02:42 PM
As for tape on the camera and mags....
If you are on a 2+ camera shoot, standard practice is to give each camera and all of it's AKS a specific tape color. For example, I grew up with red tape for "A" camera and blue tape for "B" camera (can also be other way around or different colors). Those colors usually carry over to the slates as well. Everything is given colored tape. It's really just an organizational tool for the AC's that helps to keep track of what gear goes where, etc, etc.
If the DP is using more than one film stock, a tape color is designated for each, usually based on the manufacturer tape colors as John listed above (or red/orange for tungsten and blue for daylight). This tape goes on the mags, mag cases, sometimes recans, sometimes exposed. Permacel makes white tape with "EXPOSED" printed in red which was used on the last few shows I assisted.
