vertical and horizontal streaks
#1 oscar jimenez
oscar jimenez
  • 317 posts
  • PANAMA, REPUBLIC OF PANAMA
Posted 15 May 2006 - 05:35 PM
Attached File  Frames3.bmp   76.05KB   119 downloadsHi, this just happened with a BL2 35mm arriflex cam, when camera triggers it happened on the first second of camera runnig then just disappears, Ill appreciate very much any feedback on the possible causes of this problem.
Oscar
#2 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 15 May 2006 - 06:17 PM
If this is somewhere within the first second of startup, then it is probably fogging on the stock somewhere on the feed side of the gate. Count the number of frames after the start frame, and then measure it off on the camera as it is normally laced. The light leak is very faint, only enough to fog the film when it is stationary for a long time - between takes - and it probably comes from a light falling directly on the camera wherever it was sitting at the time.
