Tapeless or p2 cards for 900
#1 Jim Jordan
Jim Jordan
  • 1 posts
Posted 18 May 2006 - 10:11 AM
I want to be able to work the 900 and would like to work with p2 cards or tapeless to get to final cut,,,, is their any options? SDI options?
#2 John Ealer
John Ealer
  • 187 posts
Posted 18 May 2006 - 04:44 PM
There's an optional card for SDI out on the SDX-900 (new cameras come with it built in). Or, you could use the SPX-800, which is the same camera, just P2 based.
J
#3 Peter J DeCrescenzo
Peter J DeCrescenzo
  • 620 posts
  • Portland, OR, USA www.peterdv.com Blog: http://herefortheweather.wordpress.com/
Posted 18 May 2006 - 09:50 PM
As John mentioned, SDI is available as an option for older SDX-900 cams, and is standard on new ones. And as he mentioned, the SPX-800 is essentially the same cam as the SDX-900, but P2-only (no tape).
Rosendahl's bonsaiDrive is a small, portable, battery-operable, _uncompressed_ SDI I/O, harddrive-based recorder/player. It's available now for about $3,500 US list price with its SDI I/O option and a 100GB 2.5" laptop-style (fairly shock resistant) harddrive. Using it with Final Cut Pro requires a SDI capture card, such as from AJA or BlackMagic. Info is available on their website here:
http://www.bonsaidrive.com/bonsai.html
Late this year Panasonic says it'll ship a new, small, portable, battery-operable, P2-based recorder/player (AJ-HPM100 @ $12K US) with built-in standard SDI I/O, DVCPRO-50 recording, upconversion to DVCPRO-HD and LCD screen. It'll interface with FCP via Firewire, or a SDI or HD-SDI capture card. A press release describing it is on Panasonic's website here:
http://tinyurl.com/m5fbl
#4 Tom Klein
Tom Klein
  • 8 posts
  • Australia
Posted 17 July 2007 - 03:09 AM
Hi Guys
Just a "Late" reply to the SDI out question from the SPX800 , I use it to capture to FCP6 via a Kona Lse, with embeded audio , direct from the camera to FCP when i'm in a hurry, it works fine, not a problem, video and audio is pristine.
I did a comparison between SDI, and P2 files import, I could not see any variance in image quality (using scopes)between either way of importing .
SDI output card on the SPX800 was an option, not a big deal $wise, the card outputs SDI from the camera and also from the VTR section of the camera, A "must" when shooting news and playing out in the field.
Cheers
Tom K :rolleyes:
