high speed HD cameras
#1
Posted 19 May 2006 - 08:58 AM
Thank you in advance
Spyros Zervos
D.o.P
Athens-Greece
#2
Posted 19 May 2006 - 04:12 PM
I can answer a lot of questions about it, but what are curious about specifically?
Kevin Zanit
#3
Posted 19 May 2006 - 05:15 PM
what I like to know, for the beggining, is how easy are these cameras - in terms of learning curve - and also what about the produced quality .How far is from 35mm? How much time you need for downloading the shots?
Are you happy with your final shots? I am a film guy and sometimes ,I find myself confused, about digital world, but anyway I must enter to that ........
Spyros
#4
Posted 20 May 2006 - 05:24 AM
Generally our clients have been extremely happy with the results. The phantom camera can take several minutes to transfer the data to storage after shots, so you will need to build this time into your shooting schedule.
Also, if you create lots of shots, you also create lots of data. So also build into your post schedule the transferring of this data and if necessary, converting it to video tape if thats the way you need to proceed. You can import directly into most non-linear editors, but if you plan on working across multiple platforms (eg cut on Avid, finish in Flame) it is better to get the images to tape so that you have a common timecode for your shots.
On one occasion, we were provided with material that had flicker on it from the wrong choice of lights. Just something to watch for.
David Cox
Baraka Post Production
www.baraka.co.uk
#5
Posted 20 May 2006 - 05:31 AM
David Cox
www.baraka.co.uk
David,
Do you remember how many FPS they were shooting?
Stephen
#6
Posted 20 May 2006 - 06:34 AM
It has probably more to do with the size of the bulb and the arc inside it than the fps you are shooting.
#7
Posted 20 May 2006 - 10:38 AM
On the last CineSpeedcam I witnessed I saw a message that clearly said that when using HMI lamps (on flicker-free of course) , they should be 6K or more otherwise a problem with flicker can occur.
That may have been for tungsten lights as well. Small tungsten lights running on AC can lights can flicker at 500fps.
Stephen
#8
Posted 20 May 2006 - 12:16 PM
David,
Stephen
Hi Stephen - I believe it was in the order of 500FPS, although we also suspected that there was some "contamination" of the light from domestic sources as it was a scene shot in a home kitchen. It wasn't too bad though and we were able to correct in post so no shot was unusable.
David Cox
#9
Posted 20 May 2006 - 12:43 PM
He Stephen - I believe it was in the order of 500FPS, although we also suspected that there was some "contamination" of the light from domestic sources as it was a scene shot in a home kitchen. It wasn't too bad though and we were able to correct in post so no shot was unusable.
David Cox
David,
If there was any 'old' flourescent lights they flicker very badly. Normal household 100w bulbs will flicker at 500fps.
Stephen
#10
Posted 06 June 2006 - 05:09 PM
#11
Posted 24 January 2007 - 04:35 AM
Thanks.
EDIT: Im planning to keep this around 720p aswell, what am i looking at as far as work flow?
Edited by Darrin P Nim, 24 January 2007 - 04:39 AM.
#12
Posted 24 January 2007 - 09:38 PM
#13
Posted 26 January 2007 - 04:05 AM
The camera seems to be about 160 ISO at 24fps and a 180 shutter.
The camera has very limited latitude, and I have found getting good results with people in the frame can be more challenging than with more forgiving subjects such as liquids, etc.
It takes 2 or 3 minutes to download a take from the camera onto the computer.
Kevin Zanit
#14
Posted 26 January 2007 - 09:57 AM
#15
Posted 26 January 2007 - 03:23 PM
Yes, actually you can talk to me about the Phantom. Rated at about 640 ISO with 10+ stops of lattitude. And it's gorgeous. Only system to give you instant gratification with a playback (without rendering) that let's you view the shot immediately. Uses 35mm format PL mount lenses with a huge chip so you get that lovely shallow depth of field as well.We rent the Phantom. You should talk to Jesse Rosen here at Abel. The thing looks fantastic and I believe he's rated it at 640 ASA, but I haven't been around to get details from him.
We also have the Phantom 65. That's a HUGE chip -- 4Kx2K. Several inches across.
#16
Posted 26 January 2007 - 03:48 PM
As far as lens mount goes, it also has a PL or PV mount, with an imager near 35mm in size.
#17
Posted 26 January 2007 - 06:19 PM
#18
Posted 26 January 2007 - 07:44 PM
I stand corrected then, but I do believe the Phantom is more sensitive with a greater exposure range.
Yes the Phantom does look more sensitive, but the picture is FAR noisier, the cinespeed has almost no noise, the picture is incredibly clean whereas the Phantom looks more like a video image with about +3 or +6 db of gain, don't quote me on the numbers, I'm just estimating from what I can see from still frames. There's also some kind of weird pattern of black pixels all over the whole image if you take a really close look at a still frame.
Each camera has it's own up and downs. I think if resolution is the most important thing you need then the Phantom HD might be the choice. But If you are more concerned about color then the Cinespeed is better.
#19
Posted 29 January 2007 - 06:19 AM
about operating with the camera, im concerned for my operator as ive noticed that with the phantom that they dont have eyepieces/viewfinders. the cinespeed does. if i some how ended up with the phantom or a camera like it (which may happen as we have found a rental house with theyre own type of highspeed hd cameras). How will my operator be able to operate? By using an on board? how have you guys handled that issue? because i notice most footage i see with this cameras are static.
How are follow focuses and non-clip on matte boxes attached?
I know i wont be able to get an exact answer but on average how much does the phantom hd and/or cinespeed rent for for a weekend in LA? with out lenses just the camera and system. please help if you can thanks.
#20
Posted 29 January 2007 - 01:15 PM
We package the Phantom HD and the Phantom 65 with either a color viewfinder or an onboard LCD monitor. We also include a pair of 24v battery blocks and a sliding baseplate for 19mm rods as well as lightweight 15mm rods. This will handle all followfocus/mattebox needs.
Book rate on the Phantom HD is $2000/day; $2750 for the Phantom 65. We also require an engineer to operate the camera and it's computer system, which is an additional charge. If one wishes to become trained as a certified operator by us we can do this as well, but there is also a charge for this.
